Volks AutosChris Nott
    jdas03's Avatar
    Jun 2009
    Surrey, UK
    597
    Xenon light adjust
    Hi all,
    Posting on behalf of a friend who has a old tt.
    the reason I'm posting here is I had an s3 and everyone was very helpful, also I understand that the lights are similar.
    anyways, as I'm sure many know a common problem is lights pointing too low. My friends car went into the garage and they tried to charge 1k for new xenon lights. I want to try a few things to try and fix the problem. I know the light height can be adjusted manually, does anyone have a noob guide or give me a rough step by step into doing this?
    Any help would be much appreciated.
    SPEC/DONE:
    Bose, 18" Wheels, Recarro, EBC Turbo Groove discs and Yellow Stuffs pads, TT Pedals, Coilovers, R-Tech Stage 1, Yellow dog bone mount, Powerflex Front ARB Bushes, FK AK Street Coilovers, LCR Front Splitter
    WANTED/TO DO:
    R32 Rear ARB (or uprated ARBs front and back), S3 Armrest, Brembos, FMIC, 3"DP, Cat Back Exhaust
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,287
    If its pointing at the floor the first step is to scan the Xenon range controller for fault codes.
    The car has automatic headlamp levelling, and if this system develops a fault, the system will point the lights at the floor as a failsafe.
    Its probably one of the ride height sensors that are mounted on the suspension.
    TD5 Land Rover Defender build
  1. Xenon light adjusters
    By Crazypete00 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th April 2012, 23:50
  2. Disconnecting automatic xenon head light adjusters....
    By Dani_B19 in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th May 2010, 14:29
  3. any adjustment on S3 xenon lights?
    By jediknight in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th December 2004, 09:24
  4. xenon lights fogging up
    By ultrasporta4vk05 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th April 2004, 15:55
  5. Xenon lights
    By Khufu in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th October 2003, 17:04
