Volks AutosSky Insurance
Results 1 to 9 of 9
Thread: 007P Flutter
    S3 TAM's Avatar
    Pocket now empty
    Oct 2009
    London & Hertfordshire
    621
    007P Flutter
    Hey All,
    Just a quick one, serviced my DV the other day "New internal's and yellow spring" ever since then it flutters the first time i take my foot off the loud pedal.
    I just find it abit strange as it only does it once and then it fine for the rest of the trip. This never used to happen.
    Just don't want to cause any damage to anything hence posting up.
    cheers in advanced.
    Revo Stage 2 with all the Gear
    BHP = 274 / Torque = 293
    Dan-Jnr's Avatar
    Jun 2011
    Manchester
    691
    Mine does this too from a cold start. Then its fine for the rest of the trip.
    2007 - Imola Yellow- Audi S3 - 305
    [8L BLOG] [8P BLOG]
    Aug 2011
    Plymouth
    755
    Add Lavis89 on Facebook
    mine does if i drive it without giving it 60 seconds or so to warm up, i guess it's just a matter of being a bit paitent when starting a journey
    Benjiman46's Avatar
    R-Tech Terrorist
    Feb 2012
    Worksop
    547
    It's the piston sticking inside the DV.. Only explanation for it... The 008 doesn't have this problem as the piston is designed differently
    Ben
    1.8 litre porsche eater!
    R-Tech Terrorist Squad - 265bhp & 275lbft
    Dan-Jnr's Avatar
    Jun 2011
    Manchester
    691
    I have the 008 and mine does this.
    [8L BLOG] [8P BLOG]
    camscockle20vT's Avatar
    The stigs ugly brother
    Nov 2010
    1,673
    Did you use the red lubrication that is recomended when reconditioning the dv?
    I only changed the spring due to it being abit worn, didnt think the piston or rubber seals needed doin.
    S3 TAM's Avatar
    Pocket now empty
    Oct 2009
    621
    I did use the Red lube that came with the rebuild kit. no real reason for servicing, just its been on there and untouched for 3 years, so i thought i would lube it up with some new bits. I did change all the seals and piston. I don't think they needed it but as i had new ones why not.
    how much red lube did/do you put on it? I put quiet alot im thinking now that i might of put to much. might take it apart tonight and have a little look at it.
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    I serviced mine earlier today.
    Used heaps of the red grease and mine hasnt "stuck" yet.
    Did you clean under the old seals before putting the new ones in? as mine had a lot of graphite coloured stuff in the grooves.
    Nov 2010
    1,673
    Just used abit dude, maybe half the size of your small finger nail if that.
    I popped abit on the spring ends as i thought it might help the friction, i serviced mine every few months, and tighten the mofo as much as you can.
  1. 1.8T flutter
    By mebrown001 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd June 2005, 17:28
  2. Fluttering Noise 1.8T
    By in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th May 2005, 15:51
  3. Fluttering noise when lifting off accelarator
    By imported_alecblack in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th March 2005, 11:51
  4. low rpm flutter?
    By djjnrj in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th January 2005, 21:49
  5. Diverter Flutter
    By HTC in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th February 2004, 16:43
