AH FabricationsEM Tuning
Results 1 to 7 of 7
    Jun 2012
    cheshunt, herts
    150
    hissing after shut down..normal ?
    Ok, I have a sound identicle to letting down a bike tyre about 2 seconds after turning the engine off. The sound comes from the back of the engine bay. simply put, is this normal. maybe the system de pressurizing ?
    Any way. In my never ending quest for knowledge and a slight bit of worry, I would like to hear from anyone with the same thing and hopefuly an explaination.
    many thanks, jamie
    Jun 2012
    285
    Do you have an induction kit? My old CRX used to hiss after being turned off, was well weird
    May 2011
    reigate surrey
    191
    mine use to do that , went around and tightened every clip up i could find and it stopped. try any pipes that are pressurised , you may have a leak somewhere. youve just fitted your 007p aint ya? check it aint leaking around the clips etc.....
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,908
    Have you been running the AC?
    TD5 Land Rover Defender build
    May 2012
    Manchester
    229
    mine does it too, mine comes from the coolant bottle, so im guessing its the cap thats slightly leaking and letting pressure out
    Jun 2012
    cheshunt, herts
    150
    ok well ive got a standard airbox. the dv is fine definatly no leaks. and no i dont run my ac as it makes the car run badly. It could well be the expansion tank but if that was loosing presure wouldnt it make the car run in correct temps ?
    i will be fitting silicone all round for turbo hoses and TIP in the next few months so as its not a huge problem i will wait and see if that sorts it.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,656
    It could be the AC unit.
    Mine makes the hissing noise and its just the AC gasses cooling and settling down.
    The AC engineer said its nothing to worry about and normal.
    I've not worried about it for 2 years and its been fine.
    A4 B5 Double Din, RNS-d, TMC, Full Sports Leather Heated with Leather Door Cards and Lower Door trims all for sale.
    Audrey's Build Thread
    RIP Audrey. She's being broken down.
    New Car, New Thread.
    Scott's Akoya Silver A8
  1. A6 2.7T 2000 - Engine losing power, shut down, smoke
    By martinmouse in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 28th April 2009, 21:48
  2. Replies: 3
    Last Post: 1st April 2008, 09:28
  3. Huming after car is shut down
    By ButchsTT in forum TT/TT-S/TT-RS Forum
    Last Post: 12th February 2007, 13:45
  4. S3 rattle on shut down?
    By Lovegroover in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd July 2006, 12:41
  5. Help - Engine management shut down!
    By imported_jamiekip in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st December 2005, 21:01
