Monster MotorsportVolks Autos
    dplovin's Avatar
    Jan 2011
    cheshire
    359
    Abs wheel speed signal (left Rear) ???
    got the abs light on in my prefacelift S3 and this fault code popped up 00290 p1726 which it says its ABS wheel speed signal (left Rear)
    im guessing its the sensor? or is there anything else it could be
    anyone ever had this problem before
    Mar 2012
    check the wiring from the sensor as well mine had worn through .Needed to replace the loom sensor was fine .
    dplovin's Avatar
    Jan 2011
    cheshire
    359
    Do you know if it's easy to replace
    Mar 2012
    My mechanic did the work . But the loom was about £32.00. It may just be something as simple as the senosr in your case . but something to bare in mind before you replace the sensor just have a quick look under the car .
    Aug 2010
    1,540
    it "should" be easy to replace.
    but if the 5mm headed bolt that holds the sensor in is rusty or rounds off/snaps, it starts being not so easy.....
    the sensor itself can also get seized in if rust has got in the hole the sensor slots into. meaning you have to fight the old sensor out usually a bit at a time. then dremel the rust out of the hole to enable you to fit the new one.
    check out the wiring first as suggested. good call.
    dplovin's Avatar
    Jan 2011
    cheshire
    359
    Cheers guys I'll give it a go over the weekend
  1. Audi a3 2.0 tdi ABS Wheel Speed Sensor; Rear Right (G44) Implausable signal
    By chrisy t in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th December 2012, 21:04
  2. ABS Wheel Speed Sensor
    By rick28 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th January 2012, 17:54
  3. ABS Wheel Speed Sensor "Tone Ring" problem
    By SonicDeathmonkey in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd July 2010, 21:47
  4. **READ ME** ABS wheel Speed sensor.....WARNING!
    By ALPINE in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th May 2010, 14:01
  5. ABS Throwing fault Wheel Speed Sensor
    Last Post: 16th January 2009, 15:15
