Monster MotorsportEM Tuning
    Dec 2009
    Wallingford, Pennsylvania, USA
    67
    What does 30amp fuse S164 do and where exacty is the fuse pump & relay alocated?
    My '98 A3 car all of a sudden won't start (though turns over nicely).
    With the fuel pump access cover removed, should I be able to hear the fuel pump at all? I don't hear anything from it even when I'm turning the engine over.
    I don't have extensive documentation on the car but I do have the Audi A3 1997 workshop manual Electrical System edition 11.01. I am suspecting it's not getting fuel because there's absolutely no smell of fuel no matter how much I pump the pedal and try to turn it over. I also don't hear any sound that I think a fuel pump should make when I turn the key in the ignition all the way up to engaging the starter. So searching this forum brings me here. I notice that the relay and fuses on top of the battery have had a problem. The 30 amp fuse in location labeled S164 has completely melted the bottom half away of the fuse! But I can't find reference to what the fuse really is used for. I also can't find the fuel pump relay. Can someone be more specific as to where its actaully located? Thanks! A picture is worth a million words here. I can't refernce to fuel pump relay in the workshop manual.
    Lucky
    98 red AUDI A3 Sport
    Aug 2010
    1,540
    are you getting a live at the fuel pump?
    every body should have one of these!
    Power Probe 3 PowerProbe III PP3 circuit tester PP319FT | eBay
    Dec 2009
    67
    Correction/Update. I Do hear the fuel pump running while I'm turning over the engine. So I guess that likely means the fuel system including relay are fine.
    So now I really have to figure out what the burned out fuse and fuse holder location is really for. I still can't reference to fuse S134 or for any of those fuses above the battery.
    I checked every fuse there was in the car and all were fine. However, one of the 30 amp fuses above the 12v battery in the engine compartment was VERY fried, literally burned the bottom half of the fuse off and did some damage to the fuse receptical it was in. However, it looks like it may have been that way for a while. I can't figure out what the fuse was supposed to be protecting. Any idea? It's one of the 3 30 Amp fuses in the box above the battery.
    Lucky
    Aug 2010
    1,540
    what engine code is it?
  1. Removing Rear Wiper, and Where to buy the bung? help :)
    By Seaneylad in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th April 2011, 17:53
  2. What is this sensor for and where does it go?! (pics)
    By nick4501 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st January 2011, 13:14
  3. What and where is the Plenhum chamber?
    By VOLTORB in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd March 2009, 19:12
  4. What is this and where does it go?
    By A3ster in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th November 2008, 21:54
  5. Where is it? What does it look like?
    By coupe-se in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th June 2007, 16:43
