Volks AutosAH Fabrications
    S3_Olly's Avatar
    Full Throttle
    Jul 2011
    Aston, Sheffield
    153
    Door blade removal
    I have just tempted the door blade removal which lead to drilling the screws out unfortunatley the white plastic strips have snapped does anyone know if you can buy these strips or if there is an alternative fix.
    i have tried audi and they dont even have a clue what im talking about, i just want to get these cleaned up and back on the car as quick as possible.
    Thanks Olly
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    if you cant find the clips, you are going to have to glue them on. You can use some sika flex or simpson construction silicone, 4 or 5 pea size dots along the blade will be more than enough. Use some masking tape to hold in position while the silicone dries. Be warned, if you use this silicone it will be very difficult to remove the blades in the future but they sure wont fall off!!
  1. Attempting door blade removal later today
    By The Doctor in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th July 2013, 14:47
  2. S3 door blade removal guide with pictures.
    By Danman1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th August 2012, 13:20
  3. Door blade removal tips
    By S3MVR in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th May 2012, 21:44
  4. door card removal?
    By unikarl in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th December 2004, 11:32
  5. A4 B6 door panel removal - help!
    By imported_Pottsy in forum In-Car Entertainment
    Last Post: 24th October 2004, 17:29
