Chris NottEM Tuning
Page 1 of 3 123 LastLast
Results 1 to 40 of 91
Like Tree1Likes
Thread: porsche brakes 4 pot
    Apr 2012
    605
    Red face porsche brakes 4 pot
    im looking into replacing my brake disc and pads very soon but not looking forward to the bill .....
    can i use leon cupra r 330mm discs instaed of the porsche one i have now,
    also what are the 4 pot calipers off eg 944 911 etc ......
    as i have to get the pads as well which i know have to be porsche ones..
    many thanks
    dan
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,439
    Cupra r disks are 323mm dude
    <tuffty/>
    Apr 2012
    605
    oh lol
    what brakes disc are 330mm then or can i get away with 323mm?/ with those calipers ??
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,263
    What calipers have you got? Boxster S or Carerra?
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,287
    Boxster S and Carrera calipers are the same :P
    He does need to find out what on earth he actually has on the car though.
    Did you ever manage to get the measuring tape out mate?
    TD5 Land Rover Defender build
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,439
    Do ypou know the origin of the brake kit you have? any pics of the discs? I assume they are a 2 piece setup....
    Problem you have here is the brackets... they will be set for diameter of 330mm discs and the offset may well be different too...
    Assuming that they are radial mount calipers then you could replace the brackets to suit the diameter and offset for 323mm lcr discs... it may be an initial outlay of course but then discs would be cheaper going forward...
    Alternatively Bill @ Badger5 does a 2 piece 330mm disc setup (same as I use on mine)... its not going to be a cheap alternative but more readily available..
    <tuffty/>
    Apr 2012
    605
    until i get taptalk on my phone ill upload pics this week
    yeah the disc's are two piece style what i am looking at for those with bill??
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,316
    you really need to find out what setup it is you've got mate. what the calipers are (part numbers is easiest) and what discs you have on currently.
    If they're a 2 piece floating setup, they're not going to be cheap, AT ALL.
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,316
    oh, and to upload pics from your phone get the photobucket app, it gives you [img] tagged links to copy and paste straight into your posts
    Apr 2012
    605
    I'll get better one in a bit
    JtotheD's Avatar
    Events Moderator
    May 2011
    Bournemouth, Dorset/ Wallingord, Oxon
    907
    well to me they look like boxter s fronts part no. 996.351.425/6 - a common disc size with these is the 330mm off an alfa brera but you need to redrill them to get the right pcd. however i've managed to source some carriers for mine that allow you to utilise the 312mm standard disc size and save all the hassle. well hopefully.. they've not arrived yet..!
    S3 8L Ming Blue 273bhp & 294lbft h
    Build/project thread
    check it out!
    Westy's Avatar
    Dec 2008
    17,263
    I haven't forgotten mate but not had the time. I'm currently on my way down to wembly to watch the Team GB football. Im working from home on Thursday so I'll get a wheel of and measure for you.
    S3 Build Thread
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,316
    Quote Originally Posted by JtotheD View Post
    Really? most carriers for these calipers are for 330s, the 312 designated carriers are for Westys boxster front / rear type caliper with a 25mm disc.
    you know the 996 fronts are intended for use with a 28mm disc don't you?
    JtotheD's Avatar
    Events Moderator
    May 2011
    907
    yeah but apparently this company i've been in contact with make them and i did mention all this and they told me they make them - If they arrive and it's as you say - which it may be - then I'll be back in contact with them! thanks for the info though - I did a lot of research and asked a lot of questions to gtech911 and he told me that you can utililise the 312mm discs...
    check it out!
    PaulS3's Avatar
    UK
    1,003
    If its any help I used to buy my Porsche "big red" brake parts from Type-911
    Their prices seemed to be reasonable.
    Audi S3 Quattro Black Edition.
    "Stick a V8 in it!"
    15,287
    The thinner disk should work fine with the 996 calipers. It just means that the pistons will sit slightly further out the caliper, but i dont see why this should cause any issue, given its only 1.5mm
    Just make sure the pads are kept 1.5mm above the minimum specified by porsche and you'll be fine.
    Apr 2012
    605
    S3 current
    Brakes
    And weird middle part of the disc
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,439
    Look like a movit kit..
    Movit Brake Question
    <tuffty/>
    Apr 2012
    605
    Is there anything better eg, take the disc I have off and thst middle bit and get a normal disc ??
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,439
    As I said mate, the problems you have is the brackets are designed for the offset and size of the discs you have... your options realistically are:
    1) stump up for replacement discs which will cost but if you retain your existing bells then you need to make sure they are clean and you use new bolts...
    b) get some custom brackets made for your calipers so you can fit sensible discs...
    z) sell um for the calipers on eBay and buy a set of Brembos and some Brembo brackets from Bill so you can fit LCR 323mm discs and cheaper Brembo pads all day long and be a happy bunny knowing you are not going to be bankrupt each time a disc/pad change comes up
    <tuffty/>
    Apr 2012
    605
    What do u think cost on discs?
    Cant Alfa disc be re-drilled?
    What would these calipers go for?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,439
    Discs for the Movit kits aren't cheap... 500 plus from what I have heard... QS Tuning supply them as far as I know so maybe give them a bell to get an idea of what they cost...
    You could get some other discs redrilled but would have to be done right by someone that knows what they are doing I guess...
    Have a look on eBay to get an idea of what they go for...
    <tuffty/>
    Apr 2012
    605
    My friend dad does machinery makes custom in most things,
    So if I had other discs re-done to fit 5x100 be fine? I'm quessing as I love the look of the calipers
    Or couldn't I get Porsche disc and re-drill them
    And take out the disc and middle from old sperate setup
    Apr 2012
    605
    Spoke to my mates dad said about re-surfacing the disc etc
    Apr 2012
    605
    what carriers did you get ?// and where from ??
    Oke Phill's Avatar
    Mar 2012
    147
    I do believe, i have the same disks, and am just about to have the same issues as you. From what i have been finding out euro car parts are the cheapest for the replacement of the section of disk which still is not cheap, i think they were about £150each ill have to dig out my working out late and post it. My friend whith his evo runs these brakes to and he has just brought his a new set from demon theives and i do believe he paid £170 each.
  28. #27
    Apr 2012
    605
    Thanks mate that would be handy
    I'm looking to re-profile mind for time being then search for a new setup
  29. #28
    Apr 2012
    605
    why couldnt just get these disc and drill them to fit 5x100 properly etc and take the middle bell case out and sell them on etc
    Alfa Romeo Brera 2.4 JTDM 20v Front Drilled Brake Discs | eBay
  30. #29
    Mar 2011
    Exeter
    90
    do the cupra r discs have the same offset as the alfa brera ones? so they can be used with porsche calipers?
    56 plate 8P S3, Phantom Black, RNSE, Cruise Control, Parking Sensors, Adaptive Bi Xenon Headlights, Interior Light Pack, FBMFSW, Center Arm Rest,
  31. #30
    Apr 2012
    605
    Not big enough I need 330mm
    Lcr are 323mm
  32. #31
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,316
    Quote Originally Posted by dancupra225 View Post
    Your question has already been answered, twice, before you asked it!
    We don't know what the difference in offset is, because you still havn't told us what kit you have!
    Until you find out what kit is on your car, it's pointless asking the same questions over and over again....
  33. #32
    Apr 2012
    605
    Tuffy has said the kit I have in a earlier post!
  34. #33
    "Stick a V8 in it!"
    15,287
    all you can do at this point is buy an alfa disk and try it on the car.
    if the offset is wrong, you'll need to have the caliper adaptors modified.
  35. #34
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,316
    Tufty said what kit it LOOKS like, who knows if he's right? Not to question Tuftys knowledge at all, but I wouldnt be happy giving out advice on what you should buy when you don't know what you have.
    Say tufty is wrong and it's not a MOVIT kit, and you spend £400 on some discs that don't fit? I guess you'd blame him then?
    I think you need to find out for sure what kit it is that you have mate, I'm not trying to be arkward, but in this case, the only person who can help, is yourself!
  36. #35
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,439
    Its a Movit kit as I mentioned further up bud... have had experience of this kit before... discs, bells and brackets are all proprietary... It was AndyC-S3's car... pretty sure he stumped up for new porker discs but they were fitted wrong as the garage hadn't cleaned the corrosion off the bells before fitting and they were not sitting flat
    <tuffty/>
  37. #36
    Apr 2012
    605
    Well I'm thinking scraping the kit
    Once I've found s cheaper option
    Re-surfacing the disc if I can
    New pads
    Then get 330mm disc re-drill them to 5x100 then see what happens and modify it to fit then
    Would anyone no what brackets would be best or use the old ones and re-do them
  38. #37
    Westy's Avatar
    Dec 2008
    17,263
    And these issues are exactly why I went for 986 Boxster brakes. So much easier
    Pedrosousa likes this.
    S3 Build Thread
  39. #38
    Apr 2012
    605
    Came with the car I do love the look of them behind the wheel
    Re-drilling the disc ain't that bad
  40. #39
    JtotheD's Avatar
    Events Moderator
    May 2011
    907
    specially made ones from gtech911
    check it out!
  41. #40
    Apr 2012
    605
    Pm me the details
  1. Porsche brakes on B6 A4?
    By JSWD32 in forum Handling
    Last Post: 11th October 2008, 18:08
  2. Neuspeed Porsche Brake Kit
    By JamS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th January 2005, 22:39
  3. Porsche Brakes - Adapter?
    By Ade_D in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th January 2005, 13:22
  4. ECS Brembo/porsche brakes and 18" RS6 replica's
    By Tin in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th November 2004, 10:59
  5. porsche brakes
    By jimboA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th May 2004, 17:24
