Badger5Sky Insurance
    Feb 2012
    20
    Gearbox problems need a bit of help
    Okay, I have a 1998 Audi a3 1.6 and I've established I need a new gearbox mine has ccompletely failed, but I would like to know the cause of failure,
    What happened was, reverse gear started playing up, and popping out of position, grinding and shaking the car badly. And then one day it popped out of reverse and the whole gearbox went stiff, like the linkage got stuck? And now I don't have reverse, 1st or 2nd gear. But in its place is, 3rd gear where reverse and first should be, and 4thgear where 2nd should be. Yes literally when I put it in where reverse should be it engages 3rd gear? Anyone know the underlying problem other than its completely knackered? Or are the gearboxes on the Audi a3 1.6's garbage.
    Many thanks
    s17atw's Avatar
    Apr 2010
    43
    Hi, 1.6 golf /a3 boxes are not the strongest
    i have rebuilt / replaced a few over the years ...... It should be rebuild able if there are no holes in the casing
    Feb 2012
    20
    Quote Originally Posted by s17atw View Post
    Are the gearboxes exactly the same on the a3's and golfs? Have you heard about this problem before or know the cause?
    Benjiman46's Avatar
    R-Tech Terrorist
    Feb 2012
    Worksop
    547
    Sounds like syncros have died, causing a broken selector fork or something along those lines inside. Won't be visible until you open it up or get All Gears in Worksop (The best around here) to have a look.
    Ben
    1.8 litre porsche eater!
    R-Tech Terrorist Squad - 265bhp & 275lbft
    Feb 2012
    20
    Okay try explain this :S got in my car was going to take it to a friends garage, and all off a sudden it's all loosened up and now it works fine, well it's a bit stuff to get in first, and reverse still pops out sometimes, but it's like it was before anything happened???
  1. need a bit of help
    By bez101 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th July 2011, 22:58
  2. heyy need a bit of help any1?
    By AudiMannDann.. in forum The Welcome Section
    Last Post: 28th March 2011, 23:13
  3. new to b5 need a bit of help
    By electricracer in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th September 2008, 08:02
  4. Forge Split-R Recirc Valve... need a bit of help!
    By markyp2002 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd May 2008, 18:55
  5. need a bit of help
    By turboaudi in forum A4/S4 forum(B5 Chassis)
    Last Post: 31st December 2006, 17:14
