Results 1 to 10 of 10
    MURRAYS444's Avatar
    Aug 2009
    Edinburgh
    789
    Limp mode and Speed signal sensor!
    Hi had my car scanned and had speed signal sensor come up and then had the fault code cleared and my car was running fine now after driving the same code keeps coming up and my car will go into limp mode + the engine management light being on will the speed signal sensor be the cause???
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,316
    If thats the only code, then yes.
    TD5 Land Rover Defender build
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,432
    Interesting, I had a dead speed signal sensor on my car and drove it for 10 miles, and it never went into limp mode? Not difficult to change though, it's down the back of the gearbox by the bulkhead side. Just need to remove airbox completely for better access. Part was around £25 many moons ago off the top of my head.
    MURRAYS444's Avatar
    Aug 2009
    Edinburgh
    789
    Cheers hopefully that is the problem its been doing my head in i'll try and get the sensor replaced and hopefully everything will be back to normal!
    MURRAYS444's Avatar
    Aug 2009
    Edinburgh
    789
    Quote Originally Posted by jojo View Post
    Aye I seen a diagram of where the part is located cheers for the advice on how to fit it that's making me a happy man
    cjsuk's Avatar
    Feb 2012
    Leeds
    561
    Aka crank shaft sensor, it can cause quite a few problems, limp mode, fail to start, epc light, crappy running, stalls etc, bit of a pig to get to but I did it so anyone can do it lol
    Ill try stuff out! If you never try and never fail, you will never know and never learn.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,432
    Quote Originally Posted by cjsuk View Post
    Mine was the speed sensor that took the speed of the car from the gearbox. Without it, the speedo never moved(along with the odo). Crank sensor is a different part and is called a crank sensor for a reason, for engine timing, not a speed sensor.
    got an S3 8L: living the dream
    Mar 2010
    Kent
    173
    yup - i had a crank sensor issue which threw on the epc light after about 10mins running.........this got worse and eventually would cause the engine to cut out.
    It ended up being heat related. When i let the engine cool down, it would start again - confirmed by checking the resistance cold and once hot. - Replacement Bosch sensor from Audi was £108 last september. Pattern parts are cheaper.
    When i had my issues it would also cause the intake cam sensor code to flag up as it was basically getting out of sync with the crank sensor whilst the crank sensor was cutting in and out.
    Well worth a replacement - i ended up being towed home off the M2.
    2002 S3 8L AMK
    MURRAYS444's Avatar
    Aug 2009
    Edinburgh
    789
    Aye I was on the way to TPS and the jubilee clip poped off the hose going to the charge pipe so never got the part today I phoned TPS and the price for it is £111 so I might be better going to Audi or searching online for a better price! chazza55 my car has begun to struggle to start up too!
    MURRAYS444's Avatar
    Aug 2009
    Edinburgh
    789
    bit of an update
    Iv ordered the crank sensor and I'll get it fitted soon hopefully this will cure the limp mode and the car will be working ok if that 's not the problem i'll order a speed sensor to hopefully cure the problem fingers crossed
  1. Limp mode and black smoke
    By audia3turrbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th May 2010, 21:41
  2. poor boost and limp mode maybe.....??
    By jiggaman in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd October 2009, 19:54
  3. limp mode and abs fault
    By smith4130 in forum Diesel forum
    Last Post: 12th March 2007, 22:50
  4. A4 1.9 TDI Motorway Speed Limp Mode
    By inigoj in forum Diesel forum
    Last Post: 25th January 2007, 21:07
  5. N75J and limp mode (overboost problems)
    By pure in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st June 2004, 18:52
