Monster MotorsportBadger5
Results 1 to 10 of 10
    Squirrelofdoom's Avatar
    Feb 2012
    Surrey
    540
    Exclamation Disconnected hose found while doing N249 - help please!! I want to drive home!!
    Hi guys,
    Was doing the N249 bypass after work...but found a worrying pipe which just wasn't connected to anything dangling around. See the picture below. The pipe is connected to what the right arrow points at, and the other end was just free.
    What is this pipe? What should it be connected to? I want to fix it before driving home because I imagine it's not good (no idea how long it's been like this either). Help please
    I finished off the bypass anyway (see below for result) will tidy it up more later. But for now I really need to know what this pipe is and where it should go :S
    Help very much appreciated!!
    Thanks,
    Aran
    rhubarb4's Avatar
    Certified Jardo Slayer
    Mar 2008
    Midlands
    1,715
    If it is from what the right arrow is pointing at and the other end is the left arrow it's your vacuum to the FPR mate you need to connect it to the nipple under the manifold, next to where the dv pipe goes, it may have split off
    <img src=http://cdn.as-static.com/vb/images/smilies/scared2.gif border=0 alt= title=Scared2 class=inlineimg />
    i wear ladies underwear to work.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,234
    Thats a vacuum line for the fpr, in connects under ur inlet manifold on the left near the charge, your fueling will have been all other the show, its ok to drive but really not recommened. Just plug it back in under the manifold, also when your get chance change it for some silicone.
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,283
    That pipe is very very important as it is for your fuel pressure regulator. You won't be going anywhere until that's connected.
    It connects to the underneath of the inlet manifold. As you face into the engine bay there are 2 nipples on the under side of the inlet manifold towards the left. This pipe will go on the one that currently has nothing attached to it.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Feb 2012
    Surrey
    540
    thank you boys!! Time to replace it for some silicone hose and get it re-attached! Reckon it's doable from ontop, or will I need to take off the manifold?
    rhubarb4's Avatar
    Mar 2008
    Midlands
    1,715
    It will cause mega problems if it's not connected, just drop off the plastic cover in front of the manifold, the one where the dipstick is and feel underneath to see if it has pulled itself off you should have 2 nipples one has your N249 delete hose from the diverted valve the other is what that pipe would have gone into.
    Chris.
    rhubarb4's Avatar
    Mar 2008
    Midlands
    1,715
    Noooo you don't need to take the mani off just feel for the nipple one the plastic cover is off you will see it too just secure it with a cable tie
    Feb 2012
    Surrey
    540
    i think it might have been off for a while :S either way, replacing with silicone and fixing now!!
    thanks guys,
    Aran
    Feb 2012
    Surrey
    540
    Hi guys,
    All done, cheers for the help! Started her up and got not engine warning lights, so that's a good start. Will take her home now and fingers crossed I haven't incorporated some leaks into the system :S
    rhubarb4's Avatar
    Mar 2008
    Midlands
    1,715
    Glad to hear dude nice cheap fix for a change.
    Chris.
  1. Pcv delete and collapsed hose any ideas or help please.
    By s33nyboy12 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd June 2012, 16:38
  2. N249 removal help please.. (pic enclosed)
    By ja3mie in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th May 2011, 17:59
  3. N249 bypass.. questions about N112 and SAI, help please (welly lol)
    By coyle in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th January 2011, 00:05
  4. S3 Silicone Hose options, help please!
    By ash_s3 in forum Tuning
    Last Post: 9th December 2006, 12:54
  5. I.T. help please!
    By MisterD in forum General Chat
    Last Post: 20th January 2003, 21:19
