AH FabricationsVolks Autos
Results 1 to 14 of 14
    cjsuk's Avatar
    Feb 2012
    Leeds
    563
    Remap has found my boost leak, bless it :) Suggestions plz
    So I sorted the vac leak a few weeks ago and the car drove brilliant allthough I could hear the boost leak still. Which un mapped at the time It diddnt trouble me. But now I'm re mapped I notice the boost leak let's say er, alot more.
    The car was hesitating now and again and I could hear the escaping air which sort of went with the hesitating ie shhhhhhhhhhh = loss of power and gorowl no shhhhhhhhhhh = power back.
    So I decided to dive under the motor yesterday to finally do a visual inspection. Smic to pancake was fine pancake to rubber pressure tube ok but then pressure tube to metal charge pipe (think thats what it is) was pushed out to one side. Whoo hoo found the leak.
    I began taking all said pipework off and cleaned all components (pancake looks nice n shiney now ). I inspected the pipe that was popped half off and it looked ok so I put it all back together, re fitted the popped off pipe give it a light tug and all looked fine.
    Test time, I took it round the block and instant transformation smooth n great power delivery, then on the way back up my street (up hill) it started misbehaving again and heard ye olde shhhhhhhhhhhhh again.
    When I parked up I went under again and the same bloody pipe had pushed out again! So again I took it off had a good look, the retaining clip first, I bent that in so it had more tension on it, then I looked at the o ring which was fine and then noticed the lugs that the spring clip hold back look worn. I got a screwdriver under the lugs and made them more prominent.
    Re- fitted, drove, all ok, and then gone again ahhhhhhhhhhhhh!
    By this time I would usually buy a new pipe but as some of you know i'm not in a position to do that, i have seen a fix (bodge) to this here : Boost leaks and Cable Ties: a guide - uk-mkivs but I think it's prob gonna get way too hot for the ties down there?.
    Do you have any other suggestions?
    This is the pipe attached to the metal pipe (pic from ebay): http://i.ebayimg.com/04/!BoCTFjwCGk~...C(kT!~~_35.JPG
    Cheers guys
    Ill try stuff out! If you never try and never fail, you will never know and never learn.
    rhubarb4's Avatar
    Certified Jardo Slayer
    Mar 2008
    Midlands
    1,715
    Can you not just get a big jubilee clip to fit round and tighten it up
    <img src=http://cdn.as-static.com/vb/images/smilies/scared2.gif border=0 alt= title=Scared2 class=inlineimg />
    i wear ladies underwear to work.
    cjsuk's Avatar
    Feb 2012
    Leeds
    563
    Quote Originally Posted by rhubarb4 View Post
    No, on the end of the pipe it's a metal coupler which slides in to the metal pipe, the coupler has 2 lugs on it that fit in to 2 lugs on the metal pipe flush then the spring clip goes in the lugs to supposedley stop the pipe popping out so there is no where to use a jubilee.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,346
    i believe this happens becuase either the clip, or the lugs that the clip seats against wear out.
    A friend had his ibiza tdi repaired by a garage for the same fault, they drilled a hole, tapped it and installed a bolt to hold the parts togther, and its been fine since.
    I guess you'd need to be sure your hole was well sealed though, or that will end up causing a boost leak itself :P
    TD5 Land Rover Defender build
    cjsuk's Avatar
    Feb 2012
    Leeds
    563
    I was thinking something along those lines, but like you say the chances of that causing a leak are quite high and it's something that cant be undone if it goes wrong = new parts which I cant do at the mo
    Jun 2012
    cheshunt, herts
    150
    i was thinking it would be worth running silicone hoses as they are stronger but as you said mate you cant do the parts right now. tough one, drive it off boost like a 80 year old until you can afford the fix ?
    "Stick a V8 in it!"
    15,346
    well if the hoses are damaged then you need new ones anyway, so trying a bodge fix with a screw isnt going to lose you anything, and might fix it.
    May 2011
    Sunny South wales
    82
    +1 for the drill hole and self tapper fix, done a few of them in the past, just a light smear of sealant on the screw before the final fit and it will be all ok, also, don't drill too close to the o ring seal.
    Aug 2011
    Plymouth
    744
    Add Lavis89 on Facebook
    if you are too paranoid also get a small o seal and put it around the bolt when screwing in, providing you drill the correct size hole and thread it well it should hold the pressure easy enough though
    Feb 2011
    Plymouth
    1,131
    Had this problem every week for over a year, did a cheap fix using a silicone reducer on the chargepipe to rubber pipe which worked for about a month. Finally after looking on eBay with no luck decided to buy an AGU chargepipe from the stealers (which is the metal pipe your on about) and the AGU rubber pipe to go with it. Get some good quality stainless steel clamps and it's fixed it. I presume you have an A3 AUM engine code?
    cjsuk's Avatar
    Feb 2012
    Leeds
    563
    Quote Originally Posted by smurfworth View Post
    Yup it's the aum, to be honest I just need a temp fix, i'm eventually going to be going silicone and fmic so that pipe I presume gets made redundant due to different routing.
    Feb 2011
    Plymouth
    1,131
    Quote Originally Posted by cjsuk View Post
    Depends on the intercooler setup you use i think, some people keep it some don't. plus, the only silicone replacement for the AGU rubber pipe has to be bought from samco japan which is very hard to get hold of. This is the type of silicone reducer i mean, you could always try this, it did fix mine for about a month or so:
    Apr 2012
    N. Wales, LL22
    1,224
    ziptie bodge will work fine
    VCDS in North Wales
    2007 A6 3.0TDi S-Line Le Mans Avant , adaptive xenon lights, sunroof, privacy glass, towbar, led rears & randomly rear seat airbags
    1999 Honda S2000 , mcb low milage jap import, fully bushed, mugen exhaust <<< for sale! <<<
    2001 Passat TDi 130 Sport < sold!! http://img.photobucket.com/albums/v343/Ste_Nova/Passat/PB140007s.jpg
    Steveo_A3_1.8t's Avatar
    Mar 2009
    Great Wakering, Southend
    196
    Happened to my remapped AUM last year, I stripped and cleaned the parts and then bent the metal tabs out on the coupler that we are talking about that grips the metal spring clip thingy, and it's been fine ever since. I have AGU charge pipe and standard hoses in my shed as I thought I would be fitting them soon after the repair lol. Any way paid £30 for the AGU charge pipe and hoses fro
    A member on here.
    "Oh shut up you tart!"
  1. S3 AMK Stage 1 Remap Logs - Possible Boost Leak ?
    By sideways steve in forum A3/S3 Forum (8L Chassis)
    Last Post: 3 Weeks Ago, 17:22
  2. Has anyone performed a boost leak test on a 2.0t fsi before.
    By slim boi in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 23rd February 2014, 16:26
  3. Found a boost leak, check your S3 now!
    By SiGainey in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th October 2011, 19:35
  4. 2.0 TDI sounds like it has a boost leak?
    By AidenUK in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th August 2011, 16:06
  5. Boost Leak
    By StevieBogan in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th December 2004, 20:47
