AH FabricationsJMB Retrofits
Results 1 to 7 of 7
Thread: lambda probe
    Feb 2011
    Stoke on trent
    48
    lambda probe
    HI my 1.8 t sport a3 aum engine code failed mot today with a lambda probe error failure issused states exhaust emissions lambda reading after 2nd fast idle outside specified limits then in fault box says co/0.0 lambda 1122 should be 1030
    I know there are 2 probes one before the cat and one after cat
    europarts quoted £75 for 1 and £88 for other any one know which one is likely to be playing up as i dont fancy paying for both unless i am unable to work out which one is faulty
    Mate going to run vagcom on it tomorrow but will that define which one is at fault
    cheers
    Lee
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    before the cat
    Feb 2011
    Stoke on trent
    48
    right got both lambda probes and had them fitted tonight
    anyway car runs fine but once it warm engine management light comes back on used my mates snapon diagnostic device and it comes up with 02 sensor 1 wire burn fault 02 sensor 2 wire burn fault could they be the wrong lambda probes soory did get the error code number they are not geniune sensors but not cheap ones either paid £120 ish for the 2 probes
    Feb 2011
    Stoke on trent
    48
    sorry latest update car has been stood on drive for over an hour and a half switched on and ecu light is now on permantley
    any ideas would be great thanks
    lee
    MattW86's Avatar
    May 2009
    Norn Iron
    74
    Hi Chukkie,
    I had a similar problem this year with my post cat lambda's (after i attacked it with fire, Muh ha ha) I went through 3 diff lambda's before i got it sorted. Same process as you cleared the code and within a time period the EML would come on.
    Got it sorted in the end through the help of J from Lambdapower, got a genuine bosch unit for just under a tonne and the thing hasnt dared light up again. Seems some of 3rd party parts don't play nice with the car.
    Hope this helps,
    Matt
    (N.B this is my experience with a similar problem and not a defo fix, just incase anyone with better knowledge wants to flame me) :-)
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,277
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    Bosch sensors FTW
    Feb 2011
    Stoke on trent
    48
    well finally got it sorted the front sensor was a bosch one but they had supplied the wrong sensor for the cat putting the right one in has cured the fault engine management light now stays off and no error codes can get it back into MOt centre next week and get it moted
    many thanks for all help and advice given
    cheers
    Lee
  1. A strange question regarding my AFR gauge and lambda probe...
    By S3 Paul in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th November 2011, 18:39
  2. stuck lambda probe
    By finesse in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th October 2010, 15:29
  3. lambda probe conundrum
    By kevandalice in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th July 2010, 22:00
  4. lambda probe where is it ?
    By davidjohngarty@yahoo.co.u in forum TT/TT-S/TT-RS Forum
    Last Post: 9th November 2007, 11:16
  5. Lambda probe
    By robonmac in forum Classic Audi Forum
    Last Post: 1st April 2007, 23:25
