Sky InsuranceVolks Autos
Results 1 to 13 of 13
    Mar 2011
    Exeter
    90
    Questions for people with 996 front brakes
    hi guys, ive managed to get hold of some 996 calipers after seeing and reading about the conversion,
    so, the part numbers of the calipers i have are 996. 351. 425 and 996. 351. 426.
    from what ive read am i right in saying these are the front calipers off a 996 turbo?
    i have 330mm brackets to use with them, i have read that i need alfa front discs but im unsure of exactly what model alfa they are from? i also have read that the pcd has to be re drilled to suit 5x100 stud pattern, how much is this likely to cost??
    last thing is that the caliper link pipes have to be swapped so the calipers can be mounted other way up, question is is the bigger piston supposed to be at the top or at the bottom of the caliper when fitted?
    i have tried to search for the answers but ive not managed to find any direct answers to my questions,
    thanks in advance for you help.
    56 plate 8P S3, Phantom Black, RNSE, Cruise Control, Parking Sensors, Adaptive Bi Xenon Headlights, Interior Light Pack, FBMFSW, Center Arm Rest,
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,156
    I have 986 brakes so can't answer most of your questions but I can tell you that the smallest piston needs to be at the top. This is because the smaller piston needs to make contact with the disc first as it does most of the light braking. The larger piston comes into play when you press harder.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Mar 2011
    Exeter
    90
    Thanks westy, one question down, two to go! hopefully someone will have the answers....
    Lizard-Racing's Avatar
    DTM
    Apr 2011
    Basingstoke
    121
    Why use Alfa discs when Cupra R bolt straight on? Yes you need to swap the link pipes because on a Porsche they are trailing and S3 has leading calipers. Other wise they will squeal!
    2005 DTM|Quattro|Phantom black|Custom FMI|Autotech HPFP|Full stainless turbo back exhaust|AP Coilovers|Ultra Race strut brace|H & R ARBs|Forge 6 pot calipers|Projector HIDs|Multifunction steering wheel|Cruise control|Power fold mirrors|Black 19" Cades Berns|235/35 Toyo Proxes
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,055
    As westy says, swap the cross overs and nipples around to get the leading /trailling pistons correct.
    Those parts numbers are 996 fronts indeed, colour will determine what they're from.
    Red calipers are from a Boxster S
    Black calipers are from a Carrera 2
    Silver calipers are from a Carrera 4
    Carrera 4s and turbo had different calipers again, but you needn't worry about those.
    The discs you need are 330x28mm discs from an Alfa brera, and they need the centre PCD redrilled from 5x110 to 5x100.
    Hi-Spec will re-drill the discs for £25 each + VAT. I'd recommend having them grooved whilst they're there too, again it's £25 per disc.
    You'll need some lines with M8 (I think - check first it's been a while!) fittings, available from Bill at Badger 5.
    After that, you'll just need some decent pads. DS2500's for these calipers are really cheap on Camskill at the moment, so that's where I'd be looking, unless you want to pull your face off, in which case I'd get DS3000's.
    You'll love them once they're on, they're simply epic brakes. i wish i still had mine!
    Mar 2011
    Exeter
    90
    Alfa discs are cheaper than cupra discs by a fair amount, im thinking if i need to have the caliper mounts machined to take a 323mm disc i might as well have the alfa discs drilled instead, also 330mm has to be better than 323mm in terms of brake performance right??
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,055
    Quote Originally Posted by Lizard-Racing View Post
    Not sure about the disc offset on those Alex, they might be the same as the Alfas? I never compared my two setup's side by side to be honest.
    I guess if the offset were the same, all you'd need to do it machine 3.5mm off the face of the 330mm carrier to get it working on a 323mm disc.
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,055
    Quote Originally Posted by jk_s3 View Post
    By the time you've bought plain alfa discs and had them re-drilled, you'll have spent similar to a set of LCR discs. machining the carrier is a one time expense, so I guess it depends on your preference.
    I ran 330's on mine, and 323's now on my track car. i'd say pad choice is more important
    Mar 2011
    Exeter
    90
    When you put it like that Prawn i see what you mean, thanks for the info and advice, always good hearing from someone who has been there before.
    Mar 2011
    Exeter
    90
    Lizard-racing, do you have lcr discs with 996 calipers on your car? im just wondering if the offset of lcr discs definately works with 996 calipers?
    Mar 2011
    Exeter
    90
    bump guys, still hope someone can help me!!
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,055
    You've been helped! Now it is time to help yourself sir!
    JtotheD's Avatar
    Events Moderator
    May 2011
    Bournemouth, Dorset/ Wallingord, Oxon
    907
    gtech 911 do carriers that allow you to utilise the 312mm s3 discs so just get those carriers and get some upgraded s3 discs. then get decent pads as already mentioned. job done and money saved and hassle saved redrilling different discs. unless you're desperate to run the larger dics.
    S3 8L Ming Blue 273bhp & 294lbft h
    Build/project thread
    check it out!
  1. Quick question for anyone with a new 2009 A3
    By h5djr in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th October 2011, 23:26
  2. Question for people with manual 2.5TDI Quattro Sports
    By sc00byd00byd00 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th July 2009, 14:01
  3. Stereo adaptor for people with Symphony head units
    By PVO_Dave in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd January 2008, 19:29
  4. Front ARB - question for people that have had them replaced.
    By god_thats_quick in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th June 2006, 23:15
  5. Question for those with bluetooth.
    By Dandle in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th February 2006, 20:33
