Sky InsuranceVolks Autos
Results 1 to 7 of 7
    Feb 2012
    Rutland
    132
    First logs of my S3 - help me understand!
    Hi all,
    Had the car a few months now and have never got round to logging, but last night went to visit a fellow forum member (thanks Alex!) and did a couple of 3rd gear WOT runs. The car has a B5 TIP and was mapped before I bought it by RSD Daventry. It peaked at 202 g/s but other than that I don't know much about what these logs are telling me. Would appreciate people having a quick check that everything is as it should be.
    By dancuz at 2012-07-23
    Hope these pics work.
    Thanks,
    Dan
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,273
    Looks like ok logs. Highest airflow of 202 (252bhp), no major pull on ignition timing.
    Nothing seems amiss there mate, I'm assuming the car has a stage 1 map and no major mods?
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Feb 2012
    Rutland
    132
    Quote Originally Posted by Westy View Post
    Hi Westy,
    Correct - It's a 2001 AMK and the only mod it has at present is a B5 tip to the standard airbox (currently running standard filter).
    I'm just pleased it's making roughly expected figures as it's very easy to get paranoid and think it's not as quick as it should be! Do the above logs tell you much about fuelling ie. Whether or not it's running lean?
    Westy's Avatar
    Dec 2008
    17,273
    Quote Originally Posted by dancuz View Post
    Hi Westy,
    Fuelling looks ok too mate. Nothing lower then 11 on the AFRs (Air to Fuel Ratio) on boost which is fine.
    S3 Build Thread
    Feb 2012
    Rutland
    132
    Brilliant. Thanks a lot mate
    Jun 2011
    S.E. Melbourne/ Australia
    146
    Westy, where do you see AFR?
    Shouldn't he log block 001 and 031?
    2000 Brilliant Black TT Quattro.
    2010 Daytona Grey TTRS.
    Westy's Avatar
    Dec 2008
    17,273
    Quote Originally Posted by Rosso TT View Post
    To get AFR you need to take the figures under 031 (middle column in his 1st spreadsheet) and x14.7.
    so for example 0.992 x 14.7 = 14.5
    You can put the calculation into excel to work out the whole log then make a sexy little line graph
    S3 Build Thread
  1. my first log
    By Bradderz_1988 in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th August 2011, 15:46
  2. First Timer, Looking for instant HELP pls!!
    By NCRAW in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th June 2011, 22:59
  3. First log on block 002
    By wibble111 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd April 2011, 19:45
  4. First Log of Hybrid SP51X K04 on stock map
    By docurley in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th February 2011, 07:41
  5. help, dont understand wheel spacers!
    By skanky in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st August 2006, 12:51
