EM TuningMonster Motorsport
    Jun 2012
    41
    agu timing belt.
    going to put a new one on soon just wondering if you need to lock the cam pulley and the crank or do they stay on the timing marks without moving?cheers
    Jun 2012
    41
    can anyone shine some light for me please
    coatesy's Avatar
    poking badgers with spoons
    Mouse Race Champion, Fishing the Sea Champion
    Oct 2010
    Middlesbrough, United Kingdom
    1,892
    put some paint or tipex on the crank pulley (this been the one at the bottom that connects to the crank), line up the cam with the timing mark on the cam and the rocker and finally line up the timing mark on the fly wheel as well, well they all should line up and when they do you shouldn't have any timing problems.
    i did this with my engine rebuild and we took the cams out of the head and put them back in and made sure the marks were all in the same place and it was sound
    Welly's Avatar
    Testing dodgy Chinese gear...
    Aug 2009
    Gloucestershire
    10,680
    Quote Originally Posted by a3tsportkyle View Post
    Belts on these - not too hard.
    Time up engine as is - remove belt. No locking pins on these or anything else.
    AGU doesn't have the VVT tensioner, so will be easier as it won't want to jump about.
    Fit new belt, check timing.
    Simples.
    Homer Simpson
    Wellyboots, you are quite literally my most favourite pikey in the entire world
    Jun 2012
    41
    thanks lads just from past experieces with cam belts sometime the cam pulleys jump outa place when the belts taken off.. but thanks for replies
  1. AGU timing belt interval
    By andyherd in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th November 2010, 10:32
  2. timing belt issue
    By hdailey in forum TT/TT-S/TT-RS Forum
    Last Post: 12th February 2004, 22:07
  3. S4 Timing Belt Prices
    By s4harv in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th November 2003, 15:13
  4. Timing Belt Question from a newcomer
    By RichbagggA4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd October 2003, 17:24
  5. 2.8 Timing Belt or timing Chain ????
    Last Post: 20th October 2003, 07:10
