AH FabricationsJMB Retrofits
Results 1 to 12 of 12
    Jun 2012
    289
    Where to buy GOOD CHEAP K04 for AMK?
    As above, I reckon my turbo isn't long for this life. Where can I get a quality replacement, maybe an exchange so get a bit of money back for mine, and I wouldn't be adverse to a hybrid....
    Apr 2012
    605
    hybrid cost more than just a turbo bud alot more than simple turbo change, injectors re-map unless u got stage 2 setup that would be a start to get there
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,377
    What makes you think yours is dead?
    So many people seem to think their turbo is dying when more often than not it's something else reasonably simple and comparatively cheap.
    If it IS the turbo, CR turbo's will rebuild your standard unit, or hybrid is to a spec of your choice. They also do a collect and deliver service so location isn't an issue.
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,282
    Prawn is spot on.
    Best thing to do is to send your turbo of for a rebuild. As long as the turbo housing isn't cracked you won't need a new unit. I sent my K04 off to Turbo Dynamics but mine was beyond repair. A rebuild would have been around £250 but the replacement I needed was about £700
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Jun 2012
    289
    Cheers guys, you make me see the light as always! When I bought the motor I had my mechanic give her the once over and he said theres a bit of oil getting through from the turbo - more than usual. Was advised to keep an eye on it....
    Now I did a little 0-60mph run, testing with Liquid gauge, and although I know im no launch specialist, I thought it went pretty well - until I saw it read 10.4secs! OMFG
    There was no missed gears or anything daft, everything felt better solid, ESP was off so hopefully no power being cut by engine, and yet a poor time. Car seems to be making 235bhp 222lb/ft and 19 psi boost. Surely something is awry here?
    Im gonna ask for a go in my mates S3 which is a BAM but stage 1, so should be similar. If it's a lot faster then I'll know something is definately up...
    James TQ's Avatar
    Apr 2012
    Essex
    548
    Sure the Gauge isn't just a bit naff? Go find somthing fairly equily powered have a light to light drag race
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,388
    235hp from 19psi of boost seems a bit odd to me.
    I'd suggest its not running right.
    TD5 Land Rover Defender build
    Jun 2012
    289
    In what way mate? Not making enough boost?
    Jun 2012
    289
    Quote Originally Posted by James TQ View Post
    It reads off the OBD port, so dunno really?
    "Stick a V8 in it!"
    15,388
    well the figures dont tally.
    Stock car with 225hp runs about 12psi
    You've got 19 and are only making 10hp more...
    Could be a faulty MAF if the power figure came from the Liquid guage. Need to get it checked out either way.
    Jun 2012
    289
    Well mine is the AMK so only 210 as standard I think. Not getting any codes on Liquid other than coolant temp sensor/thermostat one - (done cts, thermo is next job).
    Bit bamboozled on this tbh
    James TQ's Avatar
    Apr 2012
    Essex
    548
    how precise are the gauges, boost wise how do they 0compare to manual boostys?
  1. Where do I get a pair of K04s for my S4?
    By SonicDeathmonkey in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th June 2006, 07:49
  2. Where to buy oem or equivalent brake pads for 1.8T
    By imported_Nigma in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th May 2006, 09:47
  3. Goodyear Eagle F1 for S3in Glasgow-where to buy?
    By IanL-S3 in forum Detailing
    Last Post: 28th December 2004, 13:11
  4. Where 2 buy B&M Short Shift kit in UK for a TT?
    By Rai in forum TT/TT-S/TT-RS Forum
    Last Post: 28th April 2003, 12:33
  5. Where Can I Buy a Cheap Tent?
    By RichA3Turbo in forum General Chat
    Last Post: 19th April 2003, 15:21
