EM TuningBadger5
Results 1 to 22 of 22
Like Tree3Likes
  • 1 Post By aragorn
  • 1 Post By superkarl
  • 1 Post By Jason.s
Thread: Anyone Using 358mm Discs & Cayenne 6 Pots?
    Ryan_W's Avatar
    Mar 2010
    Stamford
    332
    Question Anyone Using 358mm Discs & Cayenne 6 Pots?
    Gents,
    Been doing some research today on the Cayenne 6 pot (17/18Z) calipers and 358mm discs, pretty much the ECS Stage 5 kit.
    Since I'm running 19" Ultraleggeras, I'll have no clearance issues, but I'm a little concerned about replacement discs...
    I see a few of you opt for the R32 334mm discs and get the PCD machined to suit our 5x100 set-up.
    Another question I have, are the adapters to run the 358mm discs easy to source? I can only assume that the generic Porsche > Audi adapters on eBay are for the use with smaller discs?
    I know we all get bored to death of these 'what breaks' thread, but after hunting the net, I still haven't found any conclusive answers, so bear with me!
    Cheers all,
    Ryan
    '02 Audi S3 - 270bhp / 283lb ft - SOLD
    '08 BMW 135i - 306bhp / 295lb ft
    '12 VW Golf GTD 170 - 168bhp / 258lb ft
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    Quite a few guys over on the SRS forum are using the 18Z caliper with a 345mm Mercedes disk, so thats another option to consider. I believe they're fairly cheap, although the offset is likely to be totally wrong for an A3.
    The same adaptor that allows you to install a 17Z for 330mm disks should also work with the 18Z for 350s as the extra offset comes from the caliper itself, rather than the bracket.
    Ryan_W likes this.
    TD5 Land Rover Defender build
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    most people use 330's i think.
    ask stacey, liquid, and sam from oz. they all run the cayenne calipers.
    Ryan_W likes this.
    Ryan_W's Avatar
    Mar 2010
    Stamford
    332
    Ah ha, I now understand! Cheers mate. I'm still a little confused with regards the mounting of the larger discs, from pictures they look to be extremely deep compared to standard S3 discs.
    I run ET 23 up front with an 8.5" wide wheel, so fingers crossed, clearance shouldn't be an issue...
    Any idea what Merc discs they're running?
    Ryan_W's Avatar
    Mar 2010
    Stamford
    332
    I guess the 334mm's would be sufficient, but lets not pretend 358mm's wouldn't look a little bit good behind some 19" Ultraleggeras
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    358's are MASSIVE1 i honestly think it would look overkill, the calipers are big enough! lol
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,469
    I have 355's on mine with 6 pots, Good but i think my master cylinder could do with bleeding a tad
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    Sparco Torino 2 sport seats, None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    Ryan_W's Avatar
    Mar 2010
    Stamford
    332
    What set-up are you using Andrew?
    As far as I'm aware, the 18Z calipers use a slightly smaller piston to the 17Z, so pedal feel is pretty much OEM in feel, opposed to the 17Z's which are really pushing the limits of the standard master cylinder...
    Jun 2009
    Leeds
    3,469
    comp brakes set up
    There not mega high spec but still very good for the money
    FOR SALE
    Lizard-Racing's Avatar
    DTM
    Apr 2011
    Hampshire
    149
    I run the 17zs on mine with 334mm discs. Pedal travel is long though, on the flip side I can run 17" wheels!
    2005 DTM|Quattro|Phantom black|HTA3076 turbo|Pag Parts turbo manifold|INA Engineering custom 8 injector manifold|Custom Garrett 900hp intercooler|Mahle Motorsport 83mm forged pistons|IE Tuscan forged rods|Autotech HPFP|Tial wastegate|S3 Injectors|3" Downpipe and full stainless exhaust|Stage 3 Southbend clutch|AP Coilovers|Ultra Race strut brace|H & R ARBs|Forge 6 pot calipers|Bi Xenons|Multifunction steering wheel|Memory seat|Cruise control|Power fold mirrors|Black 19" Cades Berns|235/35 Toyos
    s33nyboy12's Avatar
    May 2012
    East midlands
    1,380
    Ryan, what bhp you running? Do you need this brake setup? Or is it for when you get big power.......?
    I only ask because people (lizard and ALD Andrew plus others) with this setup run 500 bhp + !
    Bit overkill for stage 1 / stage 2 audi s3 IMO. Unless it is for future massive power gains.
    Cheers, Sean
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,098
    334mm r32 discs are the way forward....ok not quite as blingy or pub ammo'ish but discs are cheap and easily available (paid £120 for new Ecs plain discs for mine) also they don't need machining or anything as already 5x100
    Just my 2 pence
    Power & Torque 335bhp 285ftlb
    0-60 4.64 1/4 mile 13.02
    My GTX3071r Build Thread
    http://www.audi-sport.net/vb/a3-s3-f...ld-thread.html
    "Stick a V8 in it!"
    15,370
    if your going to use the R32 disks, surely the 996 caliper is a better match?
    Its lighter, pistons are the right size for the master cylinder, and they cheaper too.
    s33nyboy12's Avatar
    May 2012
    East midlands
    1,380
    Posts 12 and 13 to this thread make good sense to me. :-) Sounds like a good option 996 callipers and r32 discs.
    Mar 2011
    Exeter
    90
    Isnt the 334mm r32 disc to large for the off the shelf mounting brackets and 996 calipers? the biggest mount ive seen from creation motorsport is for a 330mm disc with 996 calipers.
    56 plate 8P S3, Phantom Black, RNSE, Cruise Control, Parking Sensors, Adaptive Bi Xenon Headlights, Interior Light Pack, FBMFSW, Center Arm Rest,
    DTM
    Apr 2011
    Hampshire
    149
    Use Cupra R discs and 996 turbo front calipers with those brackets
    Mar 2011
    Exeter
    90
    arent cupra r discs 323mm? so then there would be some area of pad that isnt touchin the disc?? sorry if this is a slightly off topic...
    DTM
    Apr 2011
    Hampshire
    149
    Not if you take 3mm off the adapter brackets
    "Stick a V8 in it!"
    15,370
    Quote Originally Posted by jk_s3 View Post
    They're radial mount calipers, if it doesnt clear, you can simply shim the adaptors out by a mm or two.
    Wether the offset etc is correct for the off the shelf brackets i've no idea, but it wouldnt be impossible to have some made...
    Ryan_W's Avatar
    Mar 2010
    Stamford
    332
    I'm looking to put some money in my S3 (currently stage 1), but want to sort the brakes and handling out before wacking a huge turbo into the mix.
    Having 19" wheels, i'll go with the 358's. Now I just need to find out what disc to use and where to source them....
    May 2010
    Bedford
    2,877
    £999 gets you a Ksport 8pot 356mm kit. Going to be much price difference once you faff about with getting these brakes to fit?
    Ryan_W likes this.
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,783
    The adapters for 18z and 17z are different.
    There's also the option to run ECS 2 piece R32 discs, which *should* be easier to get replacements for. ECS are strange about selling the rotors or any parts from their kits. Compbrake used to sell a suitable 350mm 2 piece but I don't think they do them anymore. You'll be hard pushed to find some outside of the ECS kit, although I heard Bill does some? Might be worth a call. I'll get some pics of mine up when they arrive...
    I've tried to fit my 6 pots a few times now. Clearance on wheels has to be really good right near the hub. Also the adapters I've got seem to foul a casting mark on the hub and I didn't have time (or power supply) to get the grinder out to make some adjustments.
    Handling mods++. HTA3582 stroker soon-ish. Hiding parts from the mrs since 2011. Build thread
  1. Is anyone using BioDiesel?
    By ianburtney in forum Diesel forum
    Last Post: 10th November 2006, 09:11
  2. anyone used LEIGH TYRES? any good?
    By jediknight in forum General Chat
    Last Post: 8th December 2004, 17:23
  3. Anyone used Monza dump vavles?
    By imported_Gibbsy in forum Tuning
    Last Post: 3rd December 2004, 18:06
  4. anyone using Jabba IHI upgrade?
    By cyuen in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th May 2004, 15:45
