Monster MotorsportChris Nott
Results 1 to 35 of 35
Like Tree14Likes
  • 2 Post By jitvv
  • 1 Post By jitvv
  • 1 Post By shariain
  • 1 Post By g60leigh
  • 3 Post By <tuffty/>
  • 2 Post By vanilla_ice
  • 2 Post By jojo
  • 1 Post By s3mad_dude
Thread: Comfort indicators fitted - one touch 3 blinks
    Oct 2006
    North Herts
    168
    Hi All,
    Just wanted to post a how to wire the Comfort indicators (one touch and it flashes indicators 3 times) ideal for lane changing on the motorway, I loved these on my Mk5 GTI and wanted them for the S3 for ages finally found the info for wiring into a 8L. I completed this on Saturday it works a treat!
    The part is available from VW p art No 000-953-227A (£40 including VAT) comes as a kit with additional relay and wiring, the wires need to be connected to the hazard switch relay :
    1) First remove radio (standard keys work as good as anything);
    2) No need to remove radio just drop it down onto the gear lever area but makesure you cover it first with a clean rag so not to scratch anything;
    3) Place fingers beneath the Piano Black trim. The trim itself, although looksrather fragile, is backed onto a metal surround. Pull firmly toward you and inslightly upwards motion. It should detach - there are approx 2-3 clips thatwill detach;
    4) Remove the cup holder by using a bladed screwdriver to press up the clipsabove it (it will make sense when you see it). Pull it directly out towardsyou;
    5) Remove the ESP switch but leave it connected - no need to unplug it from its connector just let it dangle carefully;
    6) Now you will be able to get your fingers down either side of the hazardswitch. Position them on the base of the switch (feel for it) and give it avery firm pull toward you i.e. toward the back of the car. The switch is springloaded and will take a little force;
    Once the switch is out you need to connect/splice the following wires accordingly,I soldered mine together then taped up with electrical tape (Show you'll have 3 connected on these connections)
    Relay pin numbers / Wires
    2 - (white wire on VW kit) connects to pin 5 on the S3 hazard switch(black/White)
    4 - (brown wire on VW kit) connects to pin 9 on S3 hazard switch (brown)
    5 - (green wire on VW kit) connects to pin 7 on S3 hazard switch (black/green)
    6 - (black/White on VW kit) connects to pin 2 on the S3 hazard switch(black/White)
    8 - (White/green on VW kit) connects to pin 3 on the S3 hazard switch(black/White/green)
    This is intended as a guide only therefore I accept no responsibility.
    Sorry no pics, any questions give me a shout
    Jit
    morgan306 and @udi A3 like this.
    Jit
    Audi S3
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,783
    Nice one! Might have to give this a go...
    Handling mods++. HTA3582 stroker soon-ish. Hiding parts from the mrs since 2011. Build thread
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,503
    This will be popular Jit, cheers!
    Quote Originally Posted by Sam_ View Post
    Please take some pics!
    Flubster's Avatar
    Tinkerer
    Apr 2012
    Suffolk
    36
    Hi,
    The part number you supplied is just the relay, did you buy 000 998 229 or 000 998 229 A? (The A terminates to a block, the other is just cable tails)
    Think 000 998 229 would be easier to install, assuming thats what you used?
    Non A Version Image
    A Version Image
    Dave
    Oct 2006
    North Herts
    168
    Quote Originally Posted by Flubster View Post
    Hi,
    Non A Version Image
    A Version Image
    Dave
    Hi Dave,
    Just checked the invoice I did get a000 998 229 A, typoo on my part sorry!, but seeing that you can get it without the Block connector 000 998 229 your better off getting that as i just chopped the VW connector off anyway.
    Jit
    dusty likes this.
    Jit
    Audi S3
    Flubster's Avatar
    Tinkerer
    Apr 2012
    Suffolk
    36
    Hi,
    Cheers buddy as I thought, just making sure.
    I'll take some photo's etc when I install it - looks like the difficult part is getting to it, rather than the wiring itself.
    Dave
    shariain's Avatar
    May 2004
    Glasgow
    1,173
    Been missing this since i bought the S3 so guess what I might be doing soon.
    Thanks for the info.
    Eddie S3 likes this.
    S3 1.8t Ming blue with ivory leather & 18"tt alloys
    Oct 2011
    greater mcr
    114
    Nice1 I'll have to remember this mod :-)
    wesmaster's Avatar
    Apr 2012
    Oxfordshire
    291
    I've done this on my A6 C5, was supposed to be plug and play, but connectors were different. soldered in properly works a treat! Well worth it.
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,389
    Been looking to do this so will be following your guide soon
    jitvv likes this.
    2001 S3 (AMK)
    AEM WMI Kit, Black Silicone Hoses, Badger5 TIP with Cone Filter, AH Fabrications FMIC, Relentless Manifold Downpipe & Sport Cat, Miltek Cat Back Exhaust, VAG Aero Wipers, Forge FMDV008 Re-Circ, Revo Stage 2 Remap with SPS+ Tweaks, 2.0 TFSI Coil Pack Mod, B&M Short Shift, RNS-D Retrofit, Brembo & B5 2 Piece Rotor Conversion
    Sep 2006
    Sunny Suffolk
    552
    Would the use of Scotch Locks be suitable for this?
    Oct 2006
    North Herts
    168
    Quote Originally Posted by vanilla_ice View Post
    Yes mate, that'll be fine.
    Jit
    Audi S3
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,556
    No!... anyone using scotch locks should be shot
    <tuffty/>
    Sep 2006
    Sunny Suffolk
    552
    What would you recommend as an alternative? Solder and tape?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,556
    Yes, or crimp connectors as required but if permanent splicing is required always solder/tape... scotch locks are the devils own device... they either barely make a connection to the wire as they are too big for the wire or they cut through half the thickness of the wire reducing its current carrying capacity and reducing its physical integrity... seen far too many wiring issues revolving around these things....
    They were sh*te years ago when I first got into cars (nearly 30yrs ago) and they are no better now... hate them as much as split-r's
    <tuffty/>
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,783
    Solder and heatshrink FTW. I got some heatshrink recently with adhesive built into it for extra awesomeness.
    Sep 2006
    Sunny Suffolk
    552
    <tuffty/>
    Understood
    <tuffty/> and bree9482 like this.
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,389
    Found this in the bay
    http://bit.ly/1ai1NpR
    Ordered one up so will see how well it works.
    Looks to be same set up as VW module. But a few quid cheaper.
    jojo likes this.
    2001 S3 (AMK)
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,503
    Quote Originally Posted by g60leigh View Post
    Cheers, I've just ordered one to be fitted sometime in the next 24 months.
    g60leigh and Sam_ like this.
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,389
    Quote Originally Posted by jojo View Post
    24 months !!!!
    That's a bit optimistic
    2001 S3 (AMK)
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,503
    24 months !!!!
    You know me too well...
    Apr 2011
    Dublin, Ireland
    619
    Dam it they don't post to Ireland. Typical. Would anyone be willing to order one on my behalf and post it to Dublin. I will paypal the money to you.
    B5 v1 Tip, B5 Exhaust Manifold, Beach Buggy Hybrid, Pipewerx D.P and cat bypass, Miltek resonated cat back, AH Fabs v2 Intercooler, S2000 Filter, 83mm 9.5:1 CP Pistons, Brute Rods, Bosch 550cc Injectors, Oil Catch can, N249 delete, B5 Phenolic Gasket, Devils Own Water Meth Kit, Forge baffled sump.
    H&R Springs, Koni FSD Shocks, s3dave's rear tie bars, R32 ARB's, LCR Brembo's, 18" ttrs alloys, replaced all suspension bushes, 15/20mm spacers front/rear, Vibratechnics Engine Mounts.
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,389
    Quote Originally Posted by IrishDave View Post
    Work out how much it is and I will do it for you mate
    2001 S3 (AMK)
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,503
    Dave, the genuine VW part is £40 inc of uk vat(probs £41 now with the vat increased to 20% since the thread was created), what's the vat rate in Ireland? Probs cheaper just to buy from VW?
    Apr 2011
    Dublin, Ireland
    619
    vat is 23% and with the inflated prices charged here it would be doubtfull that it is cheaper here. I will check though tomorrow.
    @g60leigh. I wouldn't have a clue what postage charges would be from the U.K. Say £28 delivered to the U.K then whatever postage is from there to here.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,503
    Took a week to arrive, no fitting instructions, but there's 5 colour coded wires, so I guess it's just a case of tapping the correct colored wire and snipping them on? I will test it first somehow and report back.
  28. #27
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,389
    Instructions are linked from the eBay listing.
    Only in German tho
    Here they are with my rough translation.
    Adapter - Installation Instructions Universe Harness Comfort Indicator Warning ! The first thing is : Disconnect the battery before beginning work First, remove the cover below the dash panel insert made ​​by them to draw on it! . This is only gesteckt.Dann the cover of the fuses you entfernen.Lösen five screws securing the storage compartment footwell. Diagnostic connector and floor lamp Klipsen.Schrauben it ab.Entfernen Höhenregulierung the grip of the steering wheel , the lower half of the steering column cover by making two Phillips screws and a Torx lösen.Nun the wiring harness in the steering column switch ( turn signal lever ) and the Zündschloßes identified. These run near the steering column to the tissue band they Zentralelektrik.Entfernen effect to perform it . Not cut, it must later drum wrapped again werden.Jetzt disconnect using the supplied power thieves the
    lines described below on  Red line . Terminal 15 Zündplus ( Cable color black )  Yellow line : Warning light switch on the left ( cable color black / white)  White line : terminal 49a ( cable color black / white / green)  Blue line : Warning light switch on the right ( black line color green)  black line : terminal 31 MASSEIN reverse order to reassemble .
    Adapter – UniverseEinbauanleitung Kabelsatz Komfort-BlinkerACHTUNG!!! Als erstes gilt: Batterie vor Beginn der Arbeiten abklemmen!Bauen Sie zuerst die Abdeckung unterhalb des Schalttafeleinsatzes aus, indem Sie sie auf sich zu ziehen. Diese ist nur gesteckt.Dann die Abdeckung der Sicherungen entfernen.Lösen Sie fünf Befestigungsschrauben des Ablagefachs Fußraum. Diagnosestecker und Fußraumleuchte aus Klipsen.Schrauben Sie den Griff der Höhenregulierung des Lenkrades ab.Entfernen sie die untere Hälfte der Lenkstockabdeckung indem Sie zwei Kreuzschrauben und eine Torxschraube lösen.Nun den Leitungsstrang des Lenkstockschalters (Blinkerhebel) und des Zündschloßes ausfindig machen. Diese laufen in der Nähe der Lenksäule zur Zentralelektrik.Entfernen sie das Gewebeband indem sie es abwickeln. Nicht aufschneiden, es muss später wieder drumgewickelt werden.Jetzt klemmen
    Sie mit Hilfe der mitgelieferten Stromdiebe die Leitungen wie unten beschrieben auf. Rote Leitung: Klemme 15 Zündplus (Leitungsfarbe schwarz) Gelbe Leitung: Warnlichtschalter links (Leitungsfarbe schwarz/weiß) Weiße Leitung: Klemme 49a (Leitungsfarbe schwarz/weiß/grün) Blaue Leitung: Warnlichtschalter rechts (Leitungsfarbe schwarz Grün) Schwarze Leitung: Klemme 31 MasseIn umgekehrter Reihenfolge wieder zusammenbauen.
    2001 S3 (AMK)
  29. #28
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,503
    Only in German tho
    Yes, I found it after I posted Leigh, seems more complex than the instructions in the first post! lol
  30. #29
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,389
    I've done this tonight. Nice and easy mod.
    I ended up getting a genuine VW one and did it within about 25 minutes.
    I've got a German one linked above going spare so if anyone interested please pm me.
    2001 S3 (AMK)
  31. #30
    s3mad_dude's Avatar
    Noggies ruuuule!
    Jan 2006
    Hampshire
    462
    Where did you get the VW kit from? Do you have any part numbers/prices? Cheers.
  32. #31
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,389
    Quote Originally Posted by s3mad_dude View Post
    All the part no's etc are in this post mate.
    2001 S3 (AMK)
  33. #32
    s3mad_dude's Avatar
    Noggies ruuuule!
    Jan 2006
    Hampshire
    462
    Ah cool - yeah I saw them but was under the impression you bought something different! *slaps forehead*
  34. #33
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,389
    Yeah mate. I bought a eBay one from Germany (link is above) but haven't used that one. I ended up getting a VW one and using that.
    2001 S3 (AMK)
  35. #34
    s3mad_dude's Avatar
    Noggies ruuuule!
    Jan 2006
    Hampshire
    462
    Yeah I'll do the same - got a vee dub dealer down the road :-) cheers mate
    g60leigh likes this.
  36. #35
    imz
    Jan 2014
    22
    Hi is the same part number (000 998 229) correct for cars with and without cruise control as well as facelift and pre facelift cars?
  1. one touch / comfort indicators
    By A3 steve in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th March 2009, 21:31
  2. One touch indicator mod Q - 2002 S3 (8L)
    By Jonny Dub in forum General Technical / How To
    Last Post: 29th February 2008, 13:39
  3. One Touch Window Closure With Remote
    By kingalA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th April 2007, 16:41
  4. One touch elec window
    By arthurfuxake in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th September 2006, 10:21
  5. One Touch Windows - GTi Anniversary
    By AL_B in forum Volkswagen and other VAG
    Last Post: 16th June 2005, 16:40
