JMB RetrofitsEM Tuning
    Apr 2012
    Revs hunting A3 1999 1.6 Sport
    After changing the clutch a year ago, the RPM has sat at approx 1100 and rocks up and down a 100 whilst driving.
    Funny thing is, just after the problem occurred the MAF sensor, full throttle body, thermostat and lamda sensor has been changed. There are no vacum leaks (checked by 3 diff garages).
    Cleared fault codes on VAG (i.e the only one = 'V60 Throttle actuator') and then is okay for exactly 2 weeks (after approx 100 miles) then starts to hunt again.
    When starting the engine, it behaves as if its gasping for air (drowning) meaning the RPM starts from approx 50 and then up to 1000 then back down to 100 (a few times) then 1100. This happens all the time, but not when the VAG has cleared the code(s) that keep coming back after the 2 weeks.
    Thing is, its only done 80k on the clock. Works very well otherwise.
    Any ideas?
    Danio's Avatar
    AUDI-MANIACS.COM
    Aug 2011
    Skelmersdale WN8
    187
    Presuming your MAF sensor again starts playing up. Try to disconnect it and check for any difference. If there is no difference then the MAF sensor needs to be replaced.
    Currently not in the country
  1. Not holding boost & Rev hunting..
    By Shy19s in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th September 2009, 21:26
  2. Rev hunting
    By Plunky in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th September 2009, 22:27
  3. 1999 1.8T Sport up for sale shortly
    By AndyCollins in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th August 2008, 09:27
  4. Does a TT Engine Fit in a 1999 A4 Quattro Sport?
    By gc48067 in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th August 2004, 16:29
Tags for this Thread
