JMB RetrofitsVolks Autos
Results 1 to 7 of 7
    Mar 2011
    9
    Angry S3/8l intermittent problem sounds like I'm running on 3 cylinders !!!
    Hi guys it's been a while since my last post !! But my cars just started running a bit strange.. It sounds like its running on 3 cylinders but it only does it now and again..sometimes I can blip the throttle and it stops and runs loverly again,,but the other times it stays !! To the extent that I have to pull over !! Soon as the cars not run for a bit the problem goes !! But as I said it don't do it all the time !! I've had it scaned and no faults came up !! I'm scratching my head guys please help me !!
    Steveo_A3_1.8t's Avatar
    Mar 2009
    Great Wakering, Southend
    196
    Next time it does it try and pull over and unplug/pull out the coil packs one at a time, atleast then you know what cylinder it is.
    It may be a coil pack, but as you say intermittent.
    Im no expert but thats what I would do mate, maybe check the condition of the wiring harnesses to the coil packs also.
    Steve
    "Oh shut up you tart!"
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,087
    Sounds like a coil pack is on its way out mate, I had the same thing and I didn't think it was as I had the car in for the coil pack recall, but it ended up being another faulty coil pack.
    Mar 2011
    9
    Sound guys I'm gona change the coil packs and check the wiring harnesses !! The cars at stage 2 and I'm scared to use it cuz I don't won't to damage the engine
    Ill post up after I've sorted it hopefully it'll solve it !!
    EDDIE
    Nilz's Avatar
    Apr 2006
    10,087
    Cool, sounds good.
    Mar 2011
    9
    So far so good guys seems to be runnig a lot smoother in fact better than it was b4 all over !!
    Happy days
    EDDIE
    Nilz's Avatar
    Apr 2006
    10,087
    What did you do??
    Change coils and wiring??
  1. Does this sound like a coilpack problem?
    By christinho in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th April 2009, 20:17
  2. HELP! Sounds like I have a geiger counter in the boot!
    By VAGMAN1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th May 2005, 14:30
  3. How to make an S3 sound like a sports hatch?
    By Chimera in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th December 2004, 08:06
  4. yeah im gonna sound like an idiot.
    By NxJxHxCedge in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th September 2004, 15:06
  5. Strange Noise - Sounds like BOV
    By godwine in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th May 2004, 22:52
