Badger5Sky Insurance
Results 1 to 21 of 21
Like Tree1Likes
  • 1 Post By jamieA3
Thread: ' turbo flutter ' ?
    Jun 2012
    cheshunt, herts
    150
    ' turbo flutter ' ?
    evening all, since buying my 1.8 t a few weeks ago. I have noticed that when i release the throtle i hear a noise from the front thats sounds like a bird cooo. Wasnt sure what it was as ive never had a tubro charged car before. after reading online and watching videos on youtube i believe the noise is commonly refered to as turbo flutter.
    anyway, is this a sign that my bov is faulty as im getting some mixed answers though google ect. some say its the DV. Whats the difference ? ( complete turbo newby )
    anyway, maybe this noise is normal, maybe not but anyone with an idea of what to do/not do I iwill be very grateful.
    jamie
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,374
    What you're hearing is called compressor stall mate, often refered to as 'flutter'
    it's down to the diaphram in your standard DV being split.
    BOV means Blow off valve, which your car shouldn't have fitted.
    it should instead have a diverter valve, or Recirculating dump valve, known as a recirc.
    You can either replace it with a new Bosch 710N part from audi for less than £30, or upgrade to a forge alloy piston type dump valve to avoid having another failling in the future for around £80.
    You'll also find the car drives better and fuel economy will increase as well with a new DV in place, as the current one is a constant leak in the boost system costing you power and efficiency.
    RIP S3dave
    May 2004
    nr Glos
    7,177
    wot he said
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    May 2012
    Manchester
    229
    check the small pipe ontop of the dump valve and make sure all associated pipes havent come off or are split. I tempereraly fitted a boost gauge to the pipe going to the dump valve which blew off after a bit of driving and caused this sound, connected the pipe back up and it went away.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    That noise is typically down to the DV (dump valve) being faulty assuming you still have the original valve as they are prone to failure... the noise you are hearing is compressor stall and is generally bad for the turbo...
    DV = diverter valve... still technically a dump valve but doesn't vent to atmosphere like 'blow off' valves do... the ECU's fitted to these cars don't like atmos valves and you will end up with running problems using one... either buy a new OEM DV or if you fancy something else then the Forge 007p or 008p
    <tuffty/>
    Jun 2012
    cheshunt, herts
    150
    thanks guys, ill just run the car like a grandad until i can get one.( below 2000 rpm ) would you all recomend a 007p from forge IE are there any gains to be had or is it just for noise.
    thanks again, jamie
    Nov 2011
    Sturminster Newton
    190
    I have recently fitted the 007p and my standard one is fine if you want it?
    A3 1.8TQS Minge blue
    Mods: AP coilovers, Strut Brace, Merc wheels, S3 brakes, hopefully going BT soon
    Aug 2011
    Plymouth
    755
    Add Lavis89 on Facebook
    if you've got the extra £20 - 30 handy you might as well pick up a FMDV008 (the new version of the 007p) i installed one today and am very happy with it, or if you're keeping it cheap, 007p, they are pretty bullet proof compared to the standard bosch valves that are very prone to splitting. not sure about power gains etc, i've only just started working on my car but i've heard it gives better thottle response
    EDIT: thats £20-30 more expensive than the 007p
    cjsuk's Avatar
    Feb 2012
    Leeds
    563
    pigeon syndrome is what I like to call it Do what's been said and you won't go wrong and spending that little more on a forge dv is a good idea like said
    Ill try stuff out! If you never try and never fail, you will never know and never learn.
    Jun 2012
    cheshunt, herts
    150
    well thanks you to all for the responses, ive inspected the dv. and hoses as far as i can see are ok. so im guessing its a internal fault or something i cant see. anyway, thanks again, ill fit a stock one for now as i am skint ( after buying the car last month )
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,383
    Stock ones work fine on 600hp RS4's, and are fit and forget.
    Better choice IMO than some aftermarket part thats 3 times the price and requires "servicing"
    TD5 Land Rover Defender build
    Jun 2012
    cheshunt, herts
    150
    yeah i cant say whether or not aftermarket ones are better or worse, but I always wonder if many parts are better over the oem parts. I mean audi obviously research there stuff and know what there doing. on the other hand, many on these cars are pushing 15 years old, so technology has got to have improved since the mid 90s. anyway this is off topic lol
    Jun 2012
    cheshunt, herts
    150
    Quote Originally Posted by Grazam View Post
    ive inboxed you mate
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,639
    My007p gives me better response! Better than OEM!
    Jun 2012
    cheshunt, herts
    150
    yeah i will be trying one when the wallet allows. until then ...
    Nov 2011
    pboro
    185
    S3 Turbo Chatter - YouTube
    mine sounds like this all the time even with all new pipes and a new forge 007 happened after stage 2 map
    Jun 2012
    chris if im right in saying youll have a cone air filter? the chatter your hearing is through there, it will do it on a standard S3 but probably louder on yours with it being stage 2
    Nov 2011
    pboro
    185
    yeah a rather large cone filter the biggest one u have probably seen, everyone kept saying that it was a bad sign but i wasnt sure.
    Jun 2012
    cheshunt, herts
    150
    jesus is that from a hummer or a monster truck ? lol
    S3_chris 11 likes this.
    Nov 2011
    pboro
    185
    i got if off a guy that was breaking his s3 cost him £199 or something like that i got it from him for a bargain of £30
    Jun 2012
    cheshunt, herts
    150
    lol seriously funny that. looks like it could run a diesel train! surely its too big though mate ?
  1. B5 Tip fitted. Turbo flutter while on boost.
    By MintyS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th August 2012, 20:22
  2. Flutter sound...turbo?
    By mikeyw in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 17th October 2011, 14:18
  3. Turbo 'Flutter'
    By NineNails in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd November 2010, 21:13
  4. Logging turbo boost with VAG-COM
    By Ram in forum VCDS (formerly VAG-COM) forum
    Last Post: 26th January 2009, 22:23
  5. CLIFFORD Car alarm (Turbo Timer thing)
    By A4Steve in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th January 2003, 13:03
