JMB RetrofitsVolks Autos
    May 2012
    103
    Urgent help needed the dash has lit up like Blackpool
    Right guys I'm cruising down motorway and the battery light comes on , then the abs a few mins later with a big red caution symbol on the led bit ! After a few mins I think the alternator is ****ed or a belt to it but the car keeps going ??? Battery doesn't die ,,, completely anyway or not enough to stop the car ? I pull over and can't see anything but ain't got a clue what I'm looking for anyway lol ! I risked it and stopped the engine , all light disappear but after a few mins of car running they come back on ? And then speedo , temp , fuel , rev counter all stop working and a amber battery is sat above the big red flashing caution symbol but again the car is still going ??? After 20 mins speedo and all others started working again and battery light went out just leaving the abs and the big flashing red caution Symbol and when pushing the button on the led it says fault with abs contact workshop ,,, I then switched off ignition again and all lights have now gone out and seem to have stayed out for now anyway ? The battery light does flicker on and off under acceleration now ?
    Anybody got any ideas
    s33nyboy12's Avatar
    May 2012
    East midlands
    1,366
    Alternator .
    Had same on old Saab of mine nearly exact same symptoms. And was alternator on that.
    May 2012
    103
    Thanks mate that's kinda what I'm hoping ! Anyone had this on there Audi ?
    Jun 2004
    Surrey, UK.
    269
    Check the voltage at the battery with the engine off and running. Should be around 11.5-12.6v. 13.5-14v with the engine running.
    May 2012
    103
    Got nothing to test it ! Will try sort something tomoz
  1. URGENT HELP needed, fault on dash!!
    By Booth_S4 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th January 2007, 17:04
  2. Urgent help needed!!!!!
    By Stuart_A3_Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th February 2004, 17:03
  3. HELP - NEED THE NUMBER FOR
    By ooooaudi in forum TT/TT-S/TT-RS Forum
    Last Post: 8th November 2003, 19:49
  4. URGENT HELP NEEDED... WHAT WOULD CAUSE....
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd July 2003, 07:50
  5. Urgent help needed
    Last Post: 13th July 2003, 09:02
