Lumbar support broken
Westy
I adjusted my lumbar support all the way in the other day and now it's packed in. I can hear the motor wiring but it stops after 1 second and the lumbar bit doesn't move at all.
I'm sure I saw a thread about how to fix this but the search function on tapatalk isn't particularly useful!
Anyone got any advice?
I have same problem with the seat being too upright and packed in working.... CBS taking the seat out and effing around with it.
Ive heard wires can break ect."......
I'd be interested in this - my drivers one is exactly the same. Im sure theres a TT Recaro seat fix around somewhere...
The same has happened to mine, I took the switch pack off the seat and it revealed the circuit board was burnt out, if you bridge the switch you can get it to work providing its not your motor! Once your sure the motor is working via bridging the switch, just solder in a small piece of wire and away you go!
