Volks AutosMonster Motorsport
Results 1 to 18 of 18
    s33nyboy12's Avatar
    May 2012
    East midlands
    1,281
    Sticking acceleration after pedal release....... Ideas???
    As the title, some of you may remember I have started and contributed to previous threads to do with over rev.
    I have noticed it does it without changing gear gear now I.e it holds revs for 1 second or so when I let off the gas without changing gear. Now I have had it to 2 specialists and phoned Audi , the clutch pedal sensor has been changed and reset and Audi said " it just does it, the tt does it aswell" like it's fine!
    So I've checked for splits there is very little hunting on idle like 15 rpm which is fine I think and no loss of power at all, and yesterday cleaned throttle body properly it did need doing. Little bit better . Obviously s3 is drive by wire but don't know what this problem could be ......
    So anyone got any ideas at all??? Like I said I've tried a few things now and problem still exists , anyone else got this problem?
    It is well annoying as sounds like I'm granny shifting and not letting off the accelerator , when I am!
    Last though on it for me is , Is the dump valve functioning correctly? Possibly dv malfunction?
    Any help appreciated, cheers. Sean
    Mar 2013
    Devon
    394
    Did you ever solve this?
    I have the same problem, its like a delay between letting off the pedal and the engine rdoing something about it.
    Any ideas?
    Shaunie Eire's Avatar
    Aug 2010
    Ireland
    69
    Hi Guys, I had the same problem with my old s3 last year, It turned out to be the clutch pedal switch. Pretty common apparently.Also check that the plastic plate thingy is on the pedal they can come off somehow and this makes the switch uses as it pushes up against it. Mine was there but I read up about it at the time and it was pretty common.
    Mar 2013
    Devon
    394
    I have checked the clutch switch with a meter and it seems ok.
    The revs also hang sometimes when you just let off in gear, so not sure the clutch switch would make a difference then?
    Mar 2013
    Devon
    394
    If the dump valve is not opening quick enough could it cause this?
    Feb 2013
    34
    Did you cure this fault ?.....Mines doing this but it only does it when your driving harder & changing gear at higher revs, nothing comes up on vagcom, And i phoned audi today & they said the clutch pedal switch was £59 + vat!
    The car's just had a dpf delete & re-map & im sure it never done it before the map :-/
    Mar 2013
    Devon
    394
    Never completely solved it, but deleting the SAI and running a dedicated braided vacuum line from the inlet manifold to dump valve had helped.
    Sounds like you have a diesel not petrol?
    No throttle in them and no dump valve.
    Possibly a dodgy map, accelerator signal, or it is running on excess oil from the crank case breather or turbo seals.
    Have you got access to vag com?
    Feb 2013
    34
    Yep...dirty diesel...lol....(bloody dpf..glad its gone)...I had a mate from pro-drive take it for a spin & he said he thinks its the map not quite right & they prob rollin road mapped it when it really should have been live mapped?...or something like that.
    Like i said, it never done it before the map...and it feels like its having a detrimental effect on the clutch & DMF because it feels like I struggle to get a smooth gear change now...even at miss daisy speed......but it only really does it when your driving the car harder...IE to over take on a dual carriage way....when your driving around town its fine...I would have thought it would do it all the time if it was the clutch switch?
    I put it on vagcom & the only thing that came back was a blown/replaced brake light bulb from 2 weeks ago..:-/
    Mar 2013
    Devon
    394
    Quote Originally Posted by Chiefnutter View Post
    Probably your map then, but worth testing clutch switch.
    To test either clutch or brake pedal switch go into engine measuring block 66. When you press the clutch pedal one of the 0 will change to 1. Pressing the brake should change two of the 0 to two 1's (two contacts so you have a backup)
    The figures should change with only a small amount of pedal travel.
    Feb 2013
    34
    Am i using a different version of vcds to everyone else ? or am i just being stoopid?
    If you plug in vagcom/vcds you can test the switch, look at:-
    Select Control Module,
    Engine
    Measuring Blocks, field 66 ?......wtf is field 66 ?....im on the measuring blocks screen, but ive only got "group" ?...& if i type 66 in
    there.......feck all happens !...lol
    Mar 2013
    Devon
    394
    Engine
    Group needs to be either 6 or 66, are you clicking the go button?
    Below is what you should see...
    Feb 2013
    34
    mines like that when i put in 06, but ive got alot more 1's & 0's in the second box......00101000........and that changes to 00101011...when i press the brake.....but nothing happens when i press the clutch.
    Ive also just read this on the ross-tech website:
    Some of the newer Engine Control Modules may use the UDS/ODX/ASAM protocols. Those modules do not support conventional Measuring Block Groups. Advanced Measuring Values will be used instead and you will check the boxes for CCS (or similar) to locate and view the readings.
    thanks for your help so far jim ;-)
    Feb 2013
    34
    on this screen the 6 changes to 3 when you press the clutch.....so im guessing it works ?
    Mar 2013
    Devon
    394
    Looks like it's working then. What year / engine is your car?
    Who did the remap?
    Feb 2013
    34
    Its a 2006 TDI 170.....AMD in Essex done the re-map & DPF delete, I can understand them thinking it was the clutch pedal switch, they havent seen the car since the re-map a few weeks ago & it sounds like a common problem from some of the threads ive seen on here....I was due to take it back today but something else cropped up, so I'll have to ring them on Monday & re-book for next weekend....just a pain in the arse them being so far away... I think they should open a new one in Bristol...;-)
    s33nyboy12's Avatar
    May 2012
    East midlands
    1,281
    This is for a3 8l ...........
    Current: 2013 Audi A3 2.0 tdi s line 8V in black SD nav+ extras, E46 BMW M3, 1971 Volvo p1800, 2014 Ford transit sport 155ps ;-)
    Previous : Focus st 225 stage 1 (265 bhp and too much torque), 2002 audi s3 bam engine completely OEM, 2001 Audi a3 1.8 TQS 221bhp and about 20 other cars, majority civics ek4/ek9 and Bmw / Audi soot chucker's!
    Mar 2013
    Devon
    394
    Explains why yours was in a different measuring block, I assumed it was an 8L.
    Sounds like going back to AMD is your best bet.
    Feb 2013
    34
    Ahhh i see....thanks s33nyboy12..yeah...sorry Jim...kinda forgot to mention its a 8p ! I done a search & found this thread, but kinda forgot it was the 8L forum....sorry my bad ;-)
  1. 17544 reacurring after remap?any ideas??
    By Jay-a3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th January 2011, 20:31
  2. Drivers Door Sticking in Warmer weather, any ideas???? drivin me mad....
    By Sarah's A3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th March 2010, 17:29
  3. after remap TURBO SQUEAL, anyone any idea?
    By s3ugly in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd April 2009, 10:35
  4. Clutch pedal sticking
    By monty77 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd February 2005, 14:58
  5. accelerator pedal
    By Mustafa4hmed in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th January 2005, 12:46
