AH FabricationsEM Tuning
Results 1 to 15 of 15
    Aug 2010
    bradford
    1,251
    Starting my build in two week at last
    Well its been a long wait but its happening soon.
    Im going to be driving another car so my car will be getting done over 2 month period slow but im doing it never touched an engine before and ill have help off my dad and another member.
    Im selling my i.e non rifle drilled rods and getting some rifle drilled ones, piston rings got, agu head got and all done by andrew on there.
    Can anyone else recomend things to change thanks and do i get new oil pump and water pump .
    Things im buying wile i strip it v3 xs mani
    Pipe werz down pipe and decat
    New 80mm tip
    Head gasket set
    Where do i get all the bolts nut and washers from too anyone if and if ya could how many do i need thanks.
    Also as its off the road ill be putting new brake pads and discs all round,two new back calipers as one has seized so handbrake not cracking at all.
    Back suspension off sand down and spray yellow as there worn and a bit rusty now.
    Last edited by <tuffty/>; 14th July 2012 at 19:51. Reason: Removed shouty text... please do not use caps....
    350bhp & 316ftlb BBT new k16 7+7 blade hybrid turbo, Welly cooler, jetex filter, relentless ported v3 manifold 3" downpipe & de-cat, liquid gauge, r32 rear arb, AGU ported and polished Head, 550cc injectors, kw v2 Coilovers, s3dave tie bars & heat sheild, milltek cat back, I.E forged rods, brembos, inline fuel pump, v3 badger 5 tip, devils own WMI kit, AGU pistons, rear grooved discs & brembo pads, ds2500 pads & EBC ultimax disc, stack boost gauge
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,851
    lol I hope seeing as this is a build up to your build thread its going to be mega-awesome
    Aug 2010
    bradford
    1,251
    LOL, I'll be taking photos but the write up won't be any good as it never is by me.... I don't know how to write anything that well..
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,851
    stop SHOUTING gazz
    Aug 2010
    bradford
    1,251
    lol or sorry ha
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,263
    Gaz get all your fixings from the dealer. Id also recommend changing the water and oil pumps.
    Have a read through my build thread as I documented everything I bought for my build.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Aug 2010
    bradford
    1,251
    thanks westy so audi for all bolts nuts and washer apart from the nordlock washers.
    iv bought my oil pump off ebay for £40, water pump im getting with my head set off a member on here.
    cannot wait to start but ****ting it at the same time.
    westy what did u do with the vvt valve after fitting the agu head
    Westy's Avatar
    Dec 2008
    17,263
    I swapped my cams and VVT from my BAM head to the AEB head. The cams will be the same but I knew the history of my BAM ones so kept them.
    S3 Build Thread
    Aug 2010
    bradford
    1,251
    thank god for that ha my cams have score marks on cyl 3 and 4 so ill keep the agu ones as they look in
    good nik with no marks on them. will the vvt be ok just putting back on and running with the agu cams then westy
    Westy's Avatar
    Dec 2008
    17,263
    Quote Originally Posted by s3gazz View Post
    Yeah all the bits are interchangeable so it'll all be fine.
    S3 Build Thread
    Aug 2010
    bradford
    1,251
    thanks westy owt else u would advise mate.
    thing im worrying about is lining up timing and pistons westy
    Westy's Avatar
    Dec 2008
    17,263
    All the timing stuff is easier then it sounds. Just make sure you mark up the teeth on the cams and mark the chain. The cams and crank pully are all marked up anyway with little marks so it should all be fairly straight forward
    S3 Build Thread
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,444
    If using the AGU cams you will need to use the cam position sensor wheel (on the end of the inlet cam) from your AMK cams.. the AGU wheel is a 2 slot designed for non VVT... the AMK will be a 4 slot..
    <tuffty/>
    Aug 2010
    bradford
    1,251
    thanks guys ill use that tuffty ill remember thanks should be fun ha .
    westy im shore ill sus it out ha with help mate off andrew.
    where is the best place and cheepest place for rifle drilled rods please anyone sold others
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,444
    Bill sells them...
    <tuffty/>
  1. Two Week Saga Continues - MAF or DV?
    By NCRAW in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th November 2011, 13:50
  2. chrome grill? help? and what else to do on a two week break?
    By S3featesV9 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th July 2011, 15:45
  3. how long from build week to delivery?
    By Eeef in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th January 2005, 17:46
  4. How long from build week to on my drive?
    By JSportback in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th November 2004, 00:23
  5. Its not just Rich who's been busy last week!
    By jimboA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th May 2004, 09:33
