EM TuningJMB Retrofits
Results 1 to 11 of 11
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,272
    DV cold relocation ideas.
    Ever since fitting my XS mani I've noticed that the DV piston can get quite dry and stick sometimes. I've been opening the DV and applying fresh grease too it once a month to keep it nice and smooth.
    I was thinking about relocating the DV to the cold side of the FMIC after the map sensor, which is the common place, but I'm worried about the WMI! Will the WMI spay end up interfering with the DV? I've taken that hose off the TB before and there has been a light mist of fluid around the TB so i'm sure it'll work it's way into the DV.
    Is anyone running WMI with the DV on the cold side? Do you get any issues? Are there any other DV locations that would be better then the nasty hot area behind the head?
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Benjiman46's Avatar
    R-Tech Terrorist
    Feb 2012
    Worksop
    547
    I don't know about the topic in question, but what is WMI? lol
    1.8 litre porsche eater!
    R-Tech Terrorist Squad - 265bhp & 275lbft
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    Quote Originally Posted by Benjiman46 View Post
    water methanol injection. makes it go faster, which is VERY NIIIIICE.
    i see there is plenty of constructive replies as per. this forum seems very quiet lately.
    westy, i think the wmi would most likely eat away the grease in the DV, defeating the object of moving it in the first place.
    but maybe you should try it. then if you find your dv is playing up and having to re-grease it, sell the relocation kit on to someone without wmi who wot have that problem.
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,098
    Mines after the WMi nozzle and can't particularly say wether it's effected the dv as I've had other issues with it, but I do think it does dry it out a bit as it seems to get sluggish after time but in fairness the supersize one has always seemed to not be anywhere near as responsive as the 007
    I haven't had to keep periodically keep greasing it as have done it 2 or 3 times in the last year but that was due to changing springs etc trying to sort other issue and thought it'll be rude not to when had it apart
    Power & Torque 335bhp 285ftlb
    0-60 4.64 1/4 mile 13.02
    My GTX3071r Build Thread
    http://www.audi-sport.net/vb/a3-s3-f...ld-thread.html
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Id say it would be fine as long as you used a high quality grease.
    Best thing i did moving the dv, like you said my old 007 used to need re-greasing every other month as itd start to stick. Id make your own cheap dv reloaction kit and run it for a month then access the dv etc.
    Westy's Avatar
    Dec 2008
    17,272
    Is there any other locations that the DV could be installed. I'm not sure whether the issue is the warm air going through the DV or just the sheer under bonnet heat at the rear of the bay. My anodised black 007P is fading from the heat!
    S3 Build Thread
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Drivers headlight area, before the WMI..
    Westy's Avatar
    Dec 2008
    17,272
    WMI is in the hard pipe directly after the FMIC so no way of getting it in before that:
    Don't want to re-locate to before the FMIC as the hose back to the TIP will be a joke. Suppose I'll just leave it as it is.
    S3 Build Thread
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    I think itd still be better before the tb, itd be alot of messing trying todo it from the drivers side!
    RIP S3dave
    May 2004
    nr Glos
    7,156
    high temp grease used in your dv neal?
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Westy's Avatar
    Dec 2008
    17,272
    Only the stuff that comes from forge in the refurb kit. Anything you recommend Beal?
    S3 Build Thread
  1. Cold Side Diverter Valve Relocation
    By grathies in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th April 2008, 17:31
  2. Ideas to liven up F1
    By Moresauce in forum Motorsport
    Last Post: 10th January 2008, 11:28
  3. Cold side relocation kit?
    By Jampublic in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th August 2007, 20:48
  4. Cold Startup Noise
    By mramage in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd January 2003, 21:52
  5. This Cold Weather
    By S3Bangs in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th January 2003, 10:49
