Volks AutosAH Fabrications
Thread: running rich?
    Sep 2011
    doncaster
    98
    running rich?
    just checked my fuel trim on my s3 8l 2000, is +4.7% in the second column block 32 vcds too high? am i running rich?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,023
    + figure suggests lean (adding fuel)... so a vac leak maybe although +/- 5% is fairly normal...
    <tuffty/>
    Sep 2011
    doncaster
    98
    any known locations for common vac leak?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,023
    Anything thats rubber or plastic... mostly under the inlet manifold... PCV, SAI, N249... all that..
    <tuffty/>
  1. Running rich and jerks on and off the throttle
    By Mattfaced in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th February 2010, 18:14
  2. 3.2 running Rich according to RR read out
    By TAC in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th December 2009, 17:23
  3. Running rich
    By Shug1874 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th May 2009, 19:34
  4. Running rich and temp
    Last Post: 1st December 2008, 14:24
  5. Running Rich or Lean???
    By Rallyman in forum VCDS (formerly VAG-COM) forum
    Last Post: 13th February 2006, 08:34
