Volks AutosChris Nott
Thread: Parking Sensors
    MrTackalakalaka's Avatar
    Jan 2012
    Truro, Cornwall
    426
    Parking Sensors
    Hello everyone
    My pre-facelift S3 has parking sensors on the rear. I have just had the car lowered and it's sitting nicely. Unfortunately it has now caused the parking sensors to go off constantly even when I have nothing behind me.
    Anyone know if you can reset/adjust them so that they don't go off constantly??
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    isnt there a switch to turn them off?
    <tuffty/>
    Jan 2012
    Truro, Cornwall
    426
    I don't think so, can't find anything that stands out. Ill see if i can find anything on google.
    London
    160
    I also have sensors and my motor is lowered to but can't see how they are going off coz you have lowered it
    Are they oem fitment?
    If they are check the control module located in the o/r panel in the boot
    Unplug it and check the connecters as the get water in there and cause all sort of problems.
    Mines caused me to unable to connect vag com as the k line wash shorting to ground
    and before that it would work at times then not work
    Dec 2008
    Essex
    Mine have stopped working a little while ago. I've checked fuse, checked all sensors, checked the little speaker in the n/s boot trim and still no joy. I'm now assuming its the module that has packed up but I cant find it. I know it's in the o/s boot panel but can't get in there as the bose amp is in the way and can't even take it out. I'm assuming you have to take the trim right apart to get the amp out? Help would be much appreciated, thanks.
  1. Parking Sensors
    By Masterm8fo in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th January 2005, 17:13
  2. Parking Sensors
    By god_thats_quick in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th September 2004, 19:00
  3. Aftermarket Rear Parking Sensors
    By hfu in forum Detailing
    Last Post: 15th April 2004, 14:15
  4. Aftermarket Rear Parking Sensors
    By hfu in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th March 2004, 13:02
  5. Retro fit Parking Sensors
    By 18ME in forum General Technical / How To
    Last Post: 17th June 2003, 15:49
