Monster MotorsportBadger5
    Feb 2012
    Sheffield
    57
    Dump Valve Issues
    Hi all
    My car is stage 1 with no mods to the airbox etc
    I recently bought from another member a forge 007 to replace my standard valve.
    Under normal driving there was no difference in sound, just the usual quiet pst, however under heavy throttle when lifting off to change gear the valve sounded louder and higher pitched, like a wheezing noise.
    I therefore fitted the yellow spring, this made little or no difference.
    Is this normal, should I fit one of the the spacers, or will it have a boost leak or something?
    Cheers Adam
    Feb 2012
    Sheffield
    57
    I think I may have installed the wrong way around hence my issues, I have now installed with the top nipple facing the sky and all seems well.
    I tried the forge pen test to check for leeks, both the 007 one and the standard dv pistons travel back a little when you push a pen all the way, leaving a small gap, which is closed when you take your finger off the nipple, hope this is correct!!
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,263
    Yep nipple upwards is the correct way. The other way won't do any harm but it will sound like you have a budgy under your bonnet
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
  1. Best Diverter Valve/Dump Valve
    By ScottyKemp in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd September 2003, 13:11
  2. Dump Valve/recirc valve?
    By Jinx in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th August 2003, 23:53
  3. Blow off valve or Dump valve ?
    By K212 in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th July 2003, 19:18
  4. Dump valves
    By waynehiscock in forum General Technical / How To
    Last Post: 28th March 2003, 18:15
  5. Diverter Values/ Dump Valves
    By Banwell in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th January 2003, 23:50
