Chris NottVolks Autos
Results 1 to 7 of 7
    Mar 2010
    North Wales
    124
    Lightbulb How to: Ambient Lighting for cheap
    I saw a thread where someone had retrofitted an ambient light unit from Audi into his front light, and thought I'd do it the cheap way!
    I've done it before on mk4 golfs (link to my how to guide)
    It was actually alot easier on the A3 as the power is already there.
    Heres the LED's I bought, £1.99 for 5 off ebay seller Phenoptix. (excellent service and good quality)
    So, After removing the interior light I drilled the holes where the marks are.
    Then I had to find a piece of plastic to hold the bulbs, then cut to shape and drill the 2 5mm holes
    Test fitted to make sure they line up
    Then glued into the holder
    I tested them by powering them up to make sure the light shines through the holes ok before I glued it into the lamp
    then wired it up
    Refitted to the car and tested, not a great pic but they work really well
    Took about half an hour to do, and actually cost 80p as I only used 2 LED's.
    Thinking about doing the rear now too
    5̶1̶ ̶m̶k̶4̶ ̶g̶t̶i̶ ̶1̶.̶8̶t̶ ̶A̶U̶M̶ ̶|̶ ̶0̶5̶ ̶A̶u̶d̶i̶ ̶A̶3̶ ̶3̶.̶2̶ ̶Q̶u̶a̶t̶t̶r̶o̶ ̶S̶-̶L̶i̶n̶e̶ ̶|̶ ̶0̶1̶ ̶A̶3̶ ̶1̶.̶8̶t̶ ̶S̶p̶o̶r̶t̶ ̶|̶ ̶0̶2̶ ̶G̶o̶l̶f̶ ̶2̶5̶t̶h̶ ̶A̶n̶n̶i̶ ̶1̶.̶8̶T̶ ̶|̶ ̶0̶3̶ ̶m̶k̶4̶ ̶G̶T̶I̶ ̶A̶U̶Q̶ ̶|̶ ̶0̶5̶ ̶L̶e̶o̶n̶ ̶F̶r̶ ̶T̶D̶I̶ ̶1̶5̶0̶ ̶|̶ ̶m̶k̶2̶ ̶g̶o̶l̶f̶ ̶g̶t̶i̶ ̶8̶v̶ |
    0̶1̶ ̶A̶u̶d̶i̶ ̶S̶3̶| 0̶1̶ ̶m̶k̶4̶ ̶g̶t̶i̶ ̶1̶.̶8̶T̶| 03 A4 3.0 Quattro Sport Saloon
    VagCom, VagTacho, MTE, Needles, Key coding, Locked beeps etc available North Wales!
    Build thread
    Mar 2010
    North Wales
    124
    On to the Rear!
    Just as simple as the front tbh.
    removed the rear light
    Took the switches out for access to drill the holes, marked them then checked that there was enough clearance at the back before I went ahead
    Drilled
    I made spacers up for each led to hold it back inside the lamp, These consisted of a piece of lego I found lying around the house!
    The spacers were glued in, the LED's were a tight fit so I didnt bother glueing them.
    Reassembled the lamp, then checked which feed I was going to link on to, Pin 5 was the switched power from the headlight switch and i earthed it from the aerial base.
    All done, I'll be Out in my car checking them when it gets dark
    Build thread
    rhubarb4's Avatar
    Certified Jardo Slayer
    Mar 2008
    Midlands
    1,715
    Nice one I may try this it looks really oem good work.
    Chris
    <img src=http://cdn.as-static.com/vb/images/smilies/scared2.gif border=0 alt= title=Scared2 class=inlineimg />
    i wear ladies underwear to work.
    Aug 2011
    Plymouth
    762
    Add Lavis89 on Facebook
    looks really simple, i may have to think about doing this myself after i sort out my air vent boost gauge (which i brought 6 months ago, and is still in a box right beside me, where it has been since the day it turned up...)
    EDIT: and thanks for the photos, always makes more sense with photos
    Mar 2010
    North Wales
    124
    Yeah, really is simple and v cheap mod too.
    I tried them last night and the fronts are great, I need to adjust the angle on the rears so they point slightly more forward though. Might not be a problem if you've got black leather but on the silver/ivory it stands out a fair bit!
    Build thread
    Apr 2013
    Budapest
    17
    It looks really original! No idea what was the reason why you made it but it looks good!
    2003 A3 5d 8L , ASZ - PD TDI - 96 KW/310Nm and blue like that 8-)
    g60jet's Avatar
    May 2008
    UK
    147
    for the front you could of just purchased 8E0919063A and drilled two holes!
    |Present: 2005 B7 Audi A4 Avant 2.0T FSI Quattro S-Line|DIS|Phatbox|Aircon'd Glove Box|Ambiant Light Pack|
    |Gf's Motor: 2003 8L Audi A3 18.T Sport | Standard |
    |Previously: SEAT LEON FR TDI|German Spec Corrado G60 JET LHD|Mk2 Golf Cab|Mk2 Fiesta 1.4s|
  1. How to guide to retro fit ambient light
    By drfeelgood in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd July 2011, 17:18
  2. Ambient light how to? (Part numbers)?
    By rob irl tdi in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th July 2010, 22:20
  3. How to?? : Full Ambient lighting fitted for 5.21
    By ALPINE in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th March 2010, 07:59
  4. How much should I sell these lights for ?
    By crypric23 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th September 2009, 02:39
  5. Source for cheap Renault Parts?
    By danksy in forum Other Brands & Models
    Last Post: 10th January 2003, 11:34
