Monster MotorsportEM Tuning
    Jun 2012
    36
    Question How long to warm up?
    Again, sorry for another post on temperature issues.
    I'm having my mechanic fit my wastegate actuator tomorrow, but also asked him to inspect the thermostat/fluctuating situation.
    I should have mentioned this before in the previous thread, but didn't see it as such an important issue:
    Basically my A3 takes f**king ages to get up to 90 degrees. The other day I had to drive to Stansted airport (70 miles from where I live). 15 minutes before leaving, I started the car and left it ticking over on my drive to see if it would heat up before leaving - the guage had barely gone over 70 degrees. Then got in the car, and only by 20 miles into the journey was it up to running temperature.
    Surely this cannot be right? Also, I'm sure it's starting to take longer and longer each time I drive it. It was never this bad before?
    Just a faulty thermo?
    Many thanks!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,556
    Wasn't your car diagnosed with a coolant temp sensor or similar issue when you went for a remap recently?
    <tuffty/>
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,368
    Just get the thermostat changed. They get old and tired and do exactly what you describe.
    You might even get a fault code saying "coolant temperature sensor, implausible signal" or "Error in mapped cooling system", which leads folk to thinking its the sensor. Its not, those codes mean the ECU can see the car isnt getting up to temperature quickly enough, or that the temperature is falling when it shouldnt be. Symptoms of a faulty thermostat.
    TD5 Land Rover Defender build
  1. How long does your heater take to warm up?
    By [Dave B] in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th January 2009, 13:45
  2. how long does your car heaters take warm up
    By khalil in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th December 2008, 13:55
  3. 2.0TDi how long to warm up to 90c
    By sukrw in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th November 2007, 23:57
  4. How long do peoples cars take to warm up??
    By S3 Dave in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th November 2007, 02:08
