Results 1 to 22 of 22
    Gizmo20VT's Avatar
    Jun 2012
    289
    Question Is my s3 8l mapped (New 3rd log included)
    Hi Guys
    New post, i would just like to get input from fellow k04 owners if my car is mapped.
    I have logged my airflow (003) and boost (115), peaks at 19 psi or so, and then drops off to around 15-16.
    Please note the wastegate was reset to 5 psi. till redline.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,023
    If you are getting 19psi then its mapped... however your airflow is low... should be 180 ish std and 200ish mapped as a rule of thumb...
    <tuffty/>
    Gizmo20VT's Avatar
    Jun 2012
    289
    Thats what is concerning me as well, I have stock box with BMC drop in filter... Suspect the airflow sensor could perhaps be faulty?
    Is it possible to reset the map to stock?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,904
    Your log only shows 1.1 bar of boost for a very short time.
    However it seems you've logged what looks like a 1st then 2nd gear pull which makes it a little difficult to see whats going on.
    Ideally you want to start logging in 3rd gear at 2000rpm, and pull thru to 6k or so. That way you have a run thats long enough to see what the engines doing over the RPM range.
    That said, i wouldnt have thaught you would be seeing those boost figures on a stock map, which indicates that it is mapped, and its quite likely that the air flow meter is faulty.
    TD5 Land Rover Defender build
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,023
    Quote Originally Posted by Gizmo20VT View Post
    Airflow like that suggests the MAF sensor... although looking at the load its not reaching full load at any point... you did do the logging runs at full throttle?
    <tuffty/>
    "Stick a V8 in it!"
    14,904
    tuffty, throttle opening is column J, but look at the time stamps, the whole thing is over too quickly as its been done in too low a gear.
    Gizmo20VT's Avatar
    Jun 2012
    289
    That was a 3rd gear WOT run :-/
    Gizmo20VT's Avatar
    Jun 2012
    289
    I Have lunch in 30 minutes, I can relog a 3rd WOT again if you would like?
    Any additional groups that i should log?
    "Stick a V8 in it!"
    14,904
    you hit full throttle at 3k at 1.6secs in, and hit the redline at 5.04...
    Maybe i'm wrong, but i really dont think a stage 1 S3 can pull thru third gear in 3.5 seconds...
    Theres also quite clearly a gearchange at 5.0-5.9secs and you go full throttle again afterwards...
    Gizmo20VT's Avatar
    Jun 2012
    289
    I will relog sir :D and post a reply after lunch. should be within the next 60 minutes....
    "Stick a V8 in it!"
    14,904
    That might be useful, get it into 3rd gear, steady state cruise at 2krpm, start logging, full throttle through third, then lift off and stop logging.
    tuffty can probably advise on other things to log, but bear in mind that the more you log the worse the sample rate gets!
    Gizmo20VT's Avatar
    Jun 2012
    289
    Did a log quick, 3rd WOT, group 003 group 115 group 118 Airflow g/s still seem low for boost levels?
    www.badger5.co.uk
    May 2004
    nr Glos
    6,939
    requested boost is a "little" more than std would be..
    so chances are there's something on it.. but very tame, and your g/s is low for that boost
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Gizmo20VT's Avatar
    Jun 2012
    289
    So try out another MAF and relog? Would a faulty airflow sensor effect boost request?
    "Stick a V8 in it!"
    14,904
    Not really, boost request is a function of requested torque (ie throttle position) and engine rpm with some corrections for things like air temperature and ignition timing.
    New MAF time!
    Gizmo20VT's Avatar
    Jun 2012
    289
    So need to find a tuner in SA and perhaps try revert it back to stock... Peace of mind
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,369
    Hi Gizmo, you could try these > VAG Services South Africa
    "Stick a V8 in it!"
    14,904
    Why would you want to do that? Just buy a new maf!
    Gizmo20VT's Avatar
    Jun 2012
    289
    Will be testing with another MAF tonight, but the fact that it drops to 16 PSI is pretty bad, had a run with my mate a3 with k04-023 conversion, running 18 psi right thru and he killed me by like LAMPOLES Also I dont know what Mapping is on the car, previous owner didnt even know it had some kind of software...
    Have done boost leak test twice.
    "Stick a V8 in it!"
    14,904
    Still, its a fairly mild map as it is, i dont see any point in making it slower...
    Gizmo20VT's Avatar
    Jun 2012
    289
    Would like to run unitronic, and would get support as well if i should add WMI, FMIC and so on.
    ZAS
    Jun 2012
    64
    Gizmo, I'm also in ZA man, give Will a call, he's very highly respected and gives great advice. Sure, PE is kak far, but he does travel every now and then (he's offered to remap my S in Cape Town), so he obviously has places he can go to get the work done.
    He's also not just someone that's going to remap you car in a parking lot and walk away, he tunes cars the old fashioned way so you'll see exactly what's up.
    He's on the carforums.co.za forum, handle is 6potpig.
    JB
  1. Am I Remapped? (data log included)
    By mikemk4gti in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th July 2012, 17:22
  2. Touble code has returned any ideas data log included
    By marty.h in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th June 2012, 12:39
  3. First Log of Hybrid SP51X K04 on stock map
    By docurley in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th February 2011, 07:41
  4. Logging turbo boost with VAG-COM
    By Ram in forum VCDS (formerly VAG-COM) forum
    Last Post: 26th January 2009, 22:23
  5. Banner AD include help????
    By Administrators in forum General Chat
    Last Post: 7th January 2003, 15:21
