Sky InsuranceAH Fabrications
Results 1 to 8 of 8
    Sep 2011
    Scotland Dumbarton
    246
    1k after hybrid fitting(pre-mapping)
    As some of you may know ive fitted a hybrid turbo xspower mani and downpipe, wellycooler forged Rods and a few other standard mods, few things the most annoying of which is the support coming off the downpipe onto the subframe actually sits on the subframe support bracket creating the most annoying vibration/rattle can I remove the support altogether or does this put the exaust under undue stress? Secondly I'm getting the fault code 16804 which is to do with rear O2 readings I believe my cause of this is that the sleeve that joins the sports cat to the standard system is not air tight an sucking in air??? And finally my fuel consumption seems quite dodgy I'm getting 0.6% additive and -2.3 multi on block 32 don't know if this helps much its just seems as if I'm dropping 5miles on the dis when I've only went a few hundred metres just wen cruising.
    All in all a lot less issues that I thought I would have. Awaiting 550 injectors and hopefully getting down to r-tech this month/aug all the way from Glasgow.
    beachbuggy's Avatar
    Surrey
    1,727
    pretty sure the rear O2 issue is because of the rear O2 sensor being in the decat, Either it needs an adapter to space it out so its not in direct exhaust flow or better still get it coded out with the remap, easy job and easier if you leave the sensor in place and plugged in,
    slappy_dunbar's Avatar
    Let's Do This
    Westchester Cty, New York USA
    227
    Quote Originally Posted by sandwich1987 View Post
    ... I'm getting 0.6% additive and -2.3 multi on block 32 ...
    Those values are nominal for any car. Nothing wrong with them at all.
    Sep 2011
    Scotland Dumbarton
    246
    I don't have a decay fitted, gt the xspower sport cat.
    Any ideas on wether I can remove the support bracket on the subframe for the downpipe without any adverse effects?
    Sep 2011
    Scotland Dumbarton
    246
    These values could change as I had only reset them 2 days previous...
    Administrators's Avatar
    Administrator
    Oxfordshire
    1,000,001,885
    Follow Administrators On Twitter
    I suspect that the Cat effciency isn't good enough... You might find that being a sports cat it will get you through the MOT but the warm up and the effciency arn't as good as the standard one. Nick will be able to sort it out when you get the remap.
    As for the bracket yes you need it or all the weight is on the turbo.
    A
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,027
    The jury is still out on using a support bracket with the XS Power/Relentless manifold due to the way it will move above when it heat cycles... the thin stainless tubing used will move all over the place (as does all tubular manis) and the fusion welded joints are going to be more prone to cracking..
    Fixing the turbo in place with the support bracket may not be helping the XS Power/Relentless manifolds longevity...
    <tuffty/>
    Sep 2011
    Scotland Dumbarton
    246
    I try to get under the car and bend the rod coming off the downpipe then, there's not a lot of leverage tho so some heat might be required. Hopefully that solves my vibration issue.
  1. Hybrid Turbo, Fitting and Map!
    By glasgowal in forum Awesome GTI
    Last Post: 14th October 2010, 17:10
  2. Hybrid fitness bootcamps
    By Shane. in forum General Chat
    Last Post: 4th May 2010, 01:02
  3. will 2005 s3 2.0 downpipe and cat fit pre facelift
    By garyrmills in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th August 2009, 15:40
  4. 09MY diffuser/ valance fit pre-facelift?
    By ~RS~ in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th March 2009, 02:12
  5. Faults found after retro-fitting Cruise
    By Von Maximo in forum VCDS (formerly VAG-COM) forum
    Last Post: 14th April 2008, 11:46
