    Jun 2012
    Redhill Surrey
    629
    Add Grale1 on Facebook
    Cone filter on AGU
    I see some people have cone filters on there cars, are you able to put a cone filter onto AGU engine? Only ask as I see there is some sort of sensor or something attached to the bottom part of the standard air box
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,453
    the pipe attatched to the bottomof the air box is the SAI (secondary air injection, used when starting from cold)
    you can simply put a small filter on the end of this, or get rid of it all. see the stickies for that.
    but yeh, putting a cone filter on is fine
    coatesy's Avatar
    poking badgers with spoons
    Mouse Race Champion, Fishing the Sea Champion
    Oct 2010
    Middlesbrough, United Kingdom
    1,892
    Quote Originally Posted by Grale1 View Post
    i believe that is your ignition amp, if you put a cone filter on your car you need to cable tie or make some thing for it to be held in place to some part of you engine bay.
    i have mine cable tied where the old air box would of been.
    Jay A3's Avatar
    come fly with me
    Mar 2011
    Greenhithe, Kent
    1,695
    As coatesy says its your ignition amp. Undo the 2 bolts holding onto the airbox and cable tie it down. On agu engine there isn't a secondary air intake (sai) - less pipes for us I guess
    <Jay A3 build thread>
    241bhp K03s - R Tech
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    If your moving the ignition amp, make sure you retain the heatsink.
    TD5 Land Rover Defender build
    marshall-12's Avatar
    Apr 2012
    203
    you on about the falt oval sensor thing that has 2 small bolts?
    i cable tied that to the side of my cone filter.
    when i had it.. theres mixed reviews with cone filters on a standard map, it sounds great! but lagged my a3 to a *****, i noticed quite a bit of difference. but a map will sort that out so im waiting till i map it before i put it back on
    UpperClass Nerds ..
  1. S3,cone filter,or a uprated panel 1???
    By warleydaddy in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th October 2008, 16:50
  2. Cone Filter
    By evilscotsman in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd June 2008, 19:45
  3. Fitted a cone filter and......
    By M44 DUB in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th February 2007, 14:17
  4. Anyone with a cone filter fitted or made a heat shield??
    By technics100 in forum Diesel forum
    Last Post: 17th January 2006, 22:29
  5. cone filters
    By imported_kris_tdi in forum Diesel forum
    Last Post: 10th January 2006, 18:52
