Sky InsuranceJMB Retrofits
Results 1 to 8 of 8
    Dec 2011
    396
    hunting at low rpm
    as above only just started where should i start its a 2000 amk s3
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,609
    Vacuum leak
    Look at all the pipes under the inlet manifold
    <tuffty/>
    camscockle20vT's Avatar
    The stigs ugly brother
    Nov 2010
    1,673
    And if no leaks, take the throttle body off nd give it a good clean.
    s33nyboy12's Avatar
    May 2012
    East midlands
    1,391
    Quote Originally Posted by camscockle20vT View Post
    Any good link to TB cleaning as every one I have tried the pictures in the guides are dead!
    MURRAYS444's Avatar
    Aug 2009
    Edinburgh
    789
    Quote Originally Posted by s33nyboy12 View Post
    Try this one matey
    How To Clean the Throttle Body: VW & Audi DIY
    Nov 2010
    1,673
    Take it that amk is electronic throttle body? If so 4 alankey bolts, one little pipe on the top, a plug to unclip, a gaskets not to lose and a intercooler pipe to come off. I always clean mine with electrical connection cleaner from maplins but break cleaner will be ok in small quantities. Dont move the flap unless you have vag com to reset it.
    MURRAYS444's Avatar
    Aug 2009
    Edinburgh
    789
    I just cleaned my TB and before the the rev counter would bounce at idle and after cleaning it out its all good no more bounce!
    Dec 2011
    396
    has anyone moved the throttle like in the cleaning gide?
  1. Flat spot low RPM
    By Greig300 in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th April 2011, 20:52
  2. S3 whirring or whinning noise low RPM?
    By pazaz in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th June 2010, 08:56
  3. Hunting/surging at low speeds when cold
    By Eeef in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th November 2005, 17:26
  4. low rpm flutter?
    By djjnrj in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th January 2005, 21:49
  5. HELP Flat spot in low RPM, looking to boost it up
    By burts90Q in forum Classic Audi Forum
    Last Post: 15th March 2004, 22:39
