Sky InsuranceAH Fabrications
Results 1 to 8 of 8
Thread: S3 overheating
    AL CPW's Avatar
    Jun 2012
    S3 overheating
    Iv got an S3 8L and recently experienced overheating hit 120 in temp and pulled stright over, turned it off and twisted off the rad cap n pop went all the water, guessed my fan or thermostat had packed up> had the thermostat done and now wondering if its the fan relay/fuse thats gone. Just wondering where the fues/realy for this is located. Its got to be either the fuse/realy or fan thats packed up as its not coming on at all.
    Hope someone can help me thanks
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    Water pump failure by the sounds... new water pump required... guessing it wasn't done on the last cam belt replacement..
    <tuffty/>
    Feb 2006
    Lincolnshire
    719
    Second the water pump, sadly.
    If its getting that high whilst driving, then suspect water pump.
    If its taking forever to get up to temp, then probably thermostat.
    Fans have no bearing on cooling whilst driving.
    Audi S3 - 2002MY - Denim Blue - Gone
    VW Polo GTI - 2011MY - Candy White - Here
    Oct 2010
    Hampshire
    294
    Agree in this case the waterpump....although thermostat failing can cause overheating aswell as underheating, I've experienced both when a thermostat has come to the end of its life. Last time it overheated whilst driving and the spring on the thermostat i took out was noticeably chunkier than the one i replaced it with, holding the stat closed when it died, causing the overheating.
    AL CPW's Avatar
    Jun 2012
    Yeah iv changed the thermostat, questioned the water pump but spoke to Audi in they thought it could be fan relay, i reckon water pump but my head is really bouncing all over the place
    Feb 2006
    Lincolnshire
    719
    Ok, is it overheating whilst being driven at speed?
    If so, I don't think the fans play a part at all, but the waterpump flowiing water through the rad does the cooling.
    If it's still overheating, then almost certainly waterpump, especially as you've ruled out a blocked thermostat by changing it.
    Fan faults would only come into play whilst stationary etc.
    Jun 2012
    Birmingham
    29
    try changing the cooling fan fuses, they're ontop of the battery in a little plastic box, you'll find they have more than likely corroded and are making a bad connection.
    May 2012
    Manchester
    229
    most definately waterpump, my car overheated last week, so thought i would change the temp gauge and thermostat, whilst i had the thermostat out i had a good poke around inside to see if there was any bits knocking about because that could cause the thermostat to be blocked closed. I couldnt repeat the words when i could feel that my waterpump had broke haha. The pump is quite close to the thermostat, so if you take that out and stick a finger or 2 in..... towards the offside of the car you will feel the waterpump impellor and you will be able to tell if its damaged.
  1. audi 2.8 overheating
    By imported_my_audi_is_brok in forum Classic Audi Forum
    Last Post: 30th October 2005, 09:21
  2. A6 Overheating 1.8T
    By karlw1 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 18th July 2005, 14:17
  3. Overheating Issue
    By Cage in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th May 2005, 21:03
  4. Golf GT/TDi 1.9 overheating (?)
    By imported_TomatoDiesel in forum Volkswagen and other VAG
    Last Post: 8th August 2004, 16:12
  5. Overheating A6 1.8T
    By SteveX in forum General Technical / How To
    Last Post: 23rd September 2003, 21:50
