JMB RetrofitsAH Fabrications
    Feb 2012
    23
    2002 S3 Headlamp washers
    I have tried searching the FAQ's and previous posts but can't find a solution to a problem i'm having with my headlamp washer jets.
    Basically my headlamp washers don't seem to work with the water pressure from the pump and I can't figure out why.
    The washer pump kicks in after a few seconds and if I disconnect the first connection to the headlamp washers I can see water pumping through the system, however the jets dont pop up when connected. I tried a little compressed air and got them to pop up fine.
    Is there something i'm missing?
    London
    160
    Maybe not enuf pressure to push the jets out as they should
    But enuf to pump water through
    s3mad_dude's Avatar
    Noggies ruuuule!
    Jan 2006
    Hampshire
    462
    Fill your washer bottle so it's full. Then re-try. If they don't pop up (and your headlamps are on) there is a problem somewhere.
    Mar 2010
    North Wales
    124
    blockage/dirt in the washer bottle restricing flow to the pump maybe? Also check that the washer nozzles arent damaged as if they've fallen out then all the pressure will be lost so they wont raise.
    5̶1̶ ̶m̶k̶4̶ ̶g̶t̶i̶ ̶1̶.̶8̶t̶ ̶A̶U̶M̶ ̶|̶ ̶0̶5̶ ̶A̶u̶d̶i̶ ̶A̶3̶ ̶3̶.̶2̶ ̶Q̶u̶a̶t̶t̶r̶o̶ ̶S̶-̶L̶i̶n̶e̶ ̶|̶ ̶0̶1̶ ̶A̶3̶ ̶1̶.̶8̶t̶ ̶S̶p̶o̶r̶t̶ ̶|̶ ̶0̶2̶ ̶G̶o̶l̶f̶ ̶2̶5̶t̶h̶ ̶A̶n̶n̶i̶ ̶1̶.̶8̶T̶ ̶|̶ ̶0̶3̶ ̶m̶k̶4̶ ̶G̶T̶I̶ ̶A̶U̶Q̶ ̶|̶ ̶0̶5̶ ̶L̶e̶o̶n̶ ̶F̶r̶ ̶T̶D̶I̶ ̶1̶5̶0̶ ̶|̶ ̶m̶k̶2̶ ̶g̶o̶l̶f̶ ̶g̶t̶i̶ ̶8̶v̶ |
    0̶1̶ ̶A̶u̶d̶i̶ ̶S̶3̶| 0̶1̶ ̶m̶k̶4̶ ̶g̶t̶i̶ ̶1̶.̶8̶T̶| 03 A4 3.0 Quattro Sport Saloon
    VagCom, VagTacho, MTE, Needles, Key coding, Locked beeps etc available North Wales!
    Build thread
    Feb 2012
    23
    I thought there wasn't enough pressure getting to the jets to push them up. The washer nozzles are still in place too... This is strange.
    I will try another pump and see if that gives more pressure.
  1. Sticking out headlamp washers - Audi dealer response
    By imported_monkeytrousers in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th March 2005, 20:10
  2. Headlamp washers sticking out
    Last Post: 6th March 2005, 20:41
  3. Headlamp washer??
    By imported_dpo in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th October 2004, 15:44
  4. Installing a Headlamp washer system
    By imported_Tariq in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th September 2004, 19:46
  5. Headlamp Washers
    By ZAF in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th October 2003, 11:13
