Badger5EM Tuning
    marshall-12's Avatar
    Apr 2012
    203
    where can i get fuel filter clips? :/
    managed to break both fuel filter clips :/ its still on as half of them are still in there but i need to change the filter and cant till i get these clips.
    they attach onto here:
    the black plastic ones you push down.
    any idea where i can get them or what there called? cant seem to find them on ebay
    cheers
    UpperClass Nerds ..
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    I think they are called Bundy fittings im not sure where you would get them apart from Audi...
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,607
    Not something I have ever seen available... and I have looked as I wanted some myself... went to a scrap yard in the end for mine... however... if you are looking to replace them on hard lines (plastic pipe) then tbh you would be better off buying the complete hose as the ends (assuming you could actually buy them) will be near on impossible to fit in the plastic pipes... they are heat shrunk on from what I can tell, don't come off without splitting the pipe and the pipe is too stiff just to push in... even if you could it wouldn't seal properly (which is why they are heat shrunk on)
    <tuffty/>
    Apr 2012
    203
    yeah had a feeling i might have to get to a scrappy.
    im not looking to change the whole pipe or end, literally just the lastic clips you pull up to alloy you topull of the pipe then push back down once new one is in
    UpperClass Nerds ..
  1. Replies: 2
    Last Post: 15th December 2004, 20:16
  2. WHERE CAN I GET AUDI CAR MAGAZINE ( HELP )
    By thumper in forum General Chat
    Last Post: 12th May 2004, 21:05
  3. Replies: 5
    Last Post: 30th October 2003, 03:20
  4. where can I get a used mass air sensor - 2.6 V6
    By hot66 in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th August 2003, 17:36
  5. Where can I get S3 interior door trim handles?
    By simonhenchie in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th July 2003, 11:18
