Volks AutosChris Nott
    jaylake21's Avatar
    Mar 2010
    Nottingham
    26
    Driveshaft/CV Removal
    Hi,
    I wondered if you guys can help i am trying to replace my driveshaft - got stuck trying to undo this:
    imgur: the simple image sharer
    cheers.
    Wanted:
    S3 Grills for Audi A3 8L
    London
    160
    You need a multi point socket and get someone to put the footbrake on while you undo it with a big bar
    What should of done is undone it when the wheel on the car and on the floor
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,379
    Put the wheel back on without the centre cap, and put the car back on the ground with the handbrake firmly applied, before trying to undo that nut.
    you'll need a BIG breaker bar, and a suitable socket. I use a 2ft bar with a length of scaffolding tube over the end.
    TD5 Land Rover Defender build
    jaylake21's Avatar
    Mar 2010
    Nottingham
    26
    Do you know what size socket i need tried a few 32mm.
    Wanted:
    Apr 2012
    you need a 30mm 12 sided socket
    jaylake21's Avatar
    Mar 2010
    Nottingham
    26
    Quote Originally Posted by b719 View Post
    Thank you - I have know been able to get if off.
    Wanted:
  1. Front driveshaft removal?
    By bazil in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th February 2012, 22:38
  2. ABS & driveshaft removal - B5 quattro
    By Griffter in forum Handling
    Last Post: 29th September 2006, 08:23
  3. Rear Bumper Removal
    By Jon in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th February 2003, 13:10
  4. Removing key stereo power off
    By mramage in forum In-Car Entertainment
    Last Post: 24th January 2003, 13:46
  5. Rear side panel removal ?
    By vwchico in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th January 2003, 07:43
