Volks AutosEM Tuning
    Jan 2005
    UK
    The lights have gone out
    Anyone had this problem before....Rear brakes lights including high level light fail to come on under gentle braking (enough that you would expect the lights to come on). I only realised something was up when a very pleasant chap nearly buried his Merc sprinter van in my boot and gestured that I may have been in the wrong. At least thats what I think he was trying to say as I told him to f**k off. I have to really stamp on the brakes for them to work, and before they start to behave themselves. If I then go back to gentle braking they stop working again. Another hard stamp and all the brake lights light up like Blackpool tower (not quite). Could it be a dirty contact somewhere? Anyone a pro when it comes to the braking system? I'm considering left foot braking from now on and preparing my insurance company for the inevitable claim.
    Feb 2004
    Middlesex
    79
    Re: The lights have gone out
    Sounds like the brake light sensor is dicky dougie, but i'm no expert.
    Aug 2003
    Surrey
    469
    Yeah, sounds like the brake light switch. I think they cost about 7 pounds and are replaced by removing the side-panel by the door, undoing some screws and sliding the lower part of the dash out from beneath the steering wheel. That gives you access to the switch, which is at the top of the brake pedal arm.
    My high-level brake light has stopped working (normal brake lights are ok) and I thought it might be the switch, so looked into replacing it.
    I haven't done it, but kept a note of this page in case I do.
    http://forums.vwvortex.com/zerothread?id=1158315
    All of what I just said implies your problem is the brake pedal switch of course. This may not be the case, so wait for more feedback/confirmation before taking this route.
    RacingTeatray's Avatar
    Freezing in Moscow
    Oct 2004
    Moscow
    244
    Yes there's a little widget under the brake-pedal that can fail/get stuck. Although on mine it caused the brake lights to stay ON after I took my foot off the brakes unless I absolutely stamped on the brakes.
    Was quite an easy DIY fix to fit a new one which cost about 7 from the main deaer.
    Jan 2005
    UK
    Cheers chaps. Will get the screw drivers and hammer out tonight and have look. Thanks for the advice.
