Monster MotorsportBadger5
Results 1 to 21 of 21
    Jun 2012
    Torqauy
    100
    Oil leaking from turbo down behind the engine....help!!
    Hey guys i aint been on awhile had no internet, anyways got the old turbo which was puffing out oil and put another turbo on but its leaking from where the turbi is bolted on to engine all the pipes r fine i didnt replace the gaskets as was skint so i really need some info for 2morw if poss please :-(
    beachbuggy's Avatar
    Surrey
    1,745
    Quote Originally Posted by Wilts View Post
    Are you talking the washers as well as gaskets? Appreciate you're skint but common on! They are like pence each, ok possibly a £ or 2 but chances are you're going to be taking it all off to replace them !
    Jun 2012
    Torqauy
    100
    Is it just the small oil feed gasket i need like? The lad seems to think its leaking from the turbo itself so i dont see how that is poss?
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    It will be leaking from the oil feed union, ..
    Jun 2012
    Torqauy
    100
    Whats the gaskets called for that mate and do i get them from audi today?
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    I think they are copper washers? sorry i have no part no....
    Jun 2012
    Torqauy
    100
    Yea i can get some from a pumbers store, the lad is convinced the pipes are not leaking but it cant come from anywhere else than the above area can it??
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Rocker cover at the back?
    Jun 2012
    Torqauy
    100
    Would he have removed this to change turbo, he said its dripping and gets worse on idle.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    Don't get them from a plumbers store... get proper VAG ones from a dealer... to do it properly you will need 2 x oil feed washers and ideally you would have replaced all the coolant ones too so I think its 7 of those from memory... 2 for the banjo on the block, 3 for 'one' coolant banjo and 2 for the other coolant banjo on the turbo as there is a spacer on one (can't remember which off hand) VAG washers are aluminium
    Its a false economy not to change them due to the amount of work required to get to them... you would do well to get the oil drain gaskets too.. again these are metal and you should buy genuine ones... one for the sump and the one under the turbo...
    They are not expensive...
    <tuffty/>
    Jun 2012
    Torqauy
    100
    Ok il go get some washers, iv just gotta wait and see wats wat later wen he has a look but it can only be the oil banjo bolt on turbo tho??
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    Either that and/or the oil drain as both would have been undone to remove the turbo...
    <tuffty/>
    Jun 2012
    Torqauy
    100
    Wheres the oil drain coz im just gunna go get my car and av a look myself, so the oil banjo bolt on turbo and oil drain which is where? Not the sump??
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    Oil feed bolts to the top of turbo as does the coolant line from the front of the car... the block coolant pipe bolts to the side of the turbo facing the block...
    Oil drain is the pipe from the bottom of the turbo to the sump...
    <tuffty/>
    Jun 2012
    Torqauy
    100
    Ok i think i know now, cos theres two holes next to each other isnt there then a single hole round other side of turbo so is only 2 of them 3 holes i need to worry about oil leaking from? Il just get the rite washers and change them.
    Jun 2012
    Torqauy
    100
    Is it hard to take the said oil feed pipe off which is bolted on the turbo to put some new washers on?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    The oil feed is on the top of the turbo so access is only really available once the manifold is off... if you have an A3 this is relatively easy, if you have an S3 then its a little more involved...
    <tuffty/>
    Jun 2012
    Torqauy
    100
    Mines the a3 so cud u give me afew steps to taking this banjo out to replace these fuked washers, and thanks mate
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    Try this...
    k03 > k03s Turbo DIY / How to / Fitting Guide (Mk4 Golf) - uk-mkivs
    There is a lot of info there and you don't need to follow the whole thing as its for swapping a turbo but all the info is there...
    Its a pretty simple job an I can normally remove a mani/K03 in an hour or less...
    <tuffty/>
    Jun 2012
    Torqauy
    100
    All sorted spent 4 bloody hours taking the turbo off/on to change all washers for new ones so no leaks now and 4hours i fort was good seeing as ive never done it. 4 so thanks for all the input i feel like ive learnt alot!!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    Result :D
    <tuffty/>
  1. Oil leak from turbo oil feed. what gasket?
    By marshall-12 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th July 2012, 19:16
  2. Turbo oil leak from seal
    By Wilts in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th June 2012, 15:34
  3. oil leak from top of engine on the right hand side
    By harvey01 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st January 2012, 20:45
  4. Oil leak from turbo inter cooler
    By john24susan in forum Diesel forum
    Last Post: 29th April 2009, 11:52
  5. oil leak from turbo pipe
    By john24susan in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th February 2008, 09:57
