Badger5JMB Retrofits
Results 1 to 8 of 8
Thread: Long crancking?
    Dec 2004
    North London
    209
    Long crancking?
    Hey all, i have noticed in the last 3,000 miles that my car sometimes takes longer to start then other times, takes like another 2 turns or so. isnt anytime specific, just now and then. i think its since i serviced it but cant be sure as dont recall paying attention to it befor.
    Any ideas as to what it is? has any1 had anything similar?
    Feb 2004
    331
    Re: Long crancking?
    Mine suffered from similar problems until I replaced the battery.
    Timbo's Avatar
    Slowest car ever round the Top Gear track?!?
    Dec 2004
    Surrey
    275
    Re: Long crancking?
    Mine does the same, but as long as it starts I'm not worrying about it!
    Dec 2004
    North London
    209
    Re: Long crancking?
    any other guesses?
    imported_plexxi
    Re: Long crancking?
    Mine cranks sligtly longer than normal when the fuel tank is almost empty.
    Always been like that.
    hopper's Avatar
    Jan 2005
    stoke-on-trent
    122
    Re: Long crancking?
    wot fuel do u use, my t-sport was like that on normal unleaded but on optimax was fine
    Dec 2004
    North London
    209
    Re: Long crancking?
    i only run it on optimax, sometimes ult imate. havent payed attention to if it does it when near empty, will have a look..
    imported_VaulterTim
    Re: Long crancking?
    You should use partial throttle when starting a hot engine, no throttle when starting a cold engine...
    I actually read that in the handbook of a car I had once... not sure what though! [img]/ubbthreads/images/graemlins/grin.gif[/img]
    As Timbo says, the ECU uses a 'cold start valve' when cold which enriches the fuel mixture therefore making it easier to start the engine.
    T
