Monster MotorsportChris Nott
Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By Danio
Thread: Seatbelt Sensor/Warning
    Daniel M's Avatar
    May 2012
    Middlesbrough
    53
    Hi, sorry to make a thread on this but I have searched and cant find what I need. Basically should my A3 have sensors/warning light/chime when seatbelts arent worn in the front? Its a 2003 tdi sport 130 as if it does they dont work.
    Thanks in advance
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    i think it can be turned on via VCDS
    Daniel M's Avatar
    May 2012
    Middlesbrough
    53
    Sorry to sound dumb but new to Audi's. VCDS is vag com??
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    Yes mate thats right..
    Danio's Avatar
    AUDI-MANIACS.COM
    Aug 2011
    Skelmersdale WN8
    186
    It is NOT possible to activate it as 8L models hasn't got belt buckle sensors. However you can still activate warning lamp on the dash but it will iluminate once you turn ignition ON and go off afterwards.
    For Best result you can put 8P belt buckles with sensor like I've got it.
    Daniel M likes this.
    Currently not in the country
    Daniel M's Avatar
    May 2012
    Middlesbrough
    53
    Quote Originally Posted by Danio View Post
    Thanks mate will leave it for now then.
    Jan 2012
    London
    35
    Hi,
    I have a 2004 8p A3 which I believe does not have seatbelt warning. I have activated it in VCDS but it still does not work.
    The seats have only one plug coming out of it and plugging into the car. I assume this is the Airbag plug.
    I am not bothered about the passenger seat but I would like to get the drivers seat to have the warning.
    What sensor would I need to install into the seat and where would it plug into as there is no cable coming up from the car.
    My instrument cluster has the seatbelt light and I have tested the audible warning through VCDS.
    Regards,
    Areeb
    Danio's Avatar
    AUDI-MANIACS.COM
    Aug 2011
    Skelmersdale WN8
    186
    On a drivers side only seatbelt buckle activate warning lamp on dash. So your seatbelt buckle must have sensor with a wire. Usually it is a black socket. If you don't have it then obviously there is no point to activate it on dash. Possibly your car hasn't got wire plugged in under seat.
    Passenger side has got sensor fitted inside the seat.
  1. Seatbelt/ ECU warning lights - should they come on at ignition?
    By Ipswich Jules in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th August 2010, 23:53
  2. **READ ME** ABS wheel Speed sensor.....WARNING!
    By ALPINE in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th May 2010, 14:01
  3. oil sensor warning....what does it mean? HELP
    By Jason-Con in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th February 2010, 00:06
  4. Coolant Sensor warning
    By SanityClause in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th March 2008, 12:11
  5. Oil Sensor Warning Indicator Stuck on
    By MingBluS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th November 2003, 22:34
