Results 1 to 15 of 15
Thread: bouncing idle
    Apr 2012
    30
    bouncing idle
    car is idleing between 740 780 rpm shown on vagcom can feel the car reving up and down.
    ive changed/checked all breather pipes under inlet manifold fitted new plugs fited new coilpack wireing loom changed thermostat new green water temp sensor ive got no fault codes anything else i can check for. unpluge maf also still happening.
    Noob
    Jun 2012
    Sussex
    65
    Oct 2011
    760
    try cleaning your maf. halfrauds sell electrical contact cleaner 3.99.
    Jul 2012
    53
    clean and re align throttle body maybe
    Apr 2012
    30
    forgot to mention ive cleaned throttle body and reset also cleaned maf but it acts the same as withe it pluged in
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    Check your vacuum lines and also boost. I have a tricky one on my golf,there was a split on the pipe between the hard pipe and pancake pipe
    Word!!!
    My A3/Martys Golf would smash that, and this guys £7000 GT9743 supercharged love machine.
    Oct 2011
    760
    drive the car with the maf unplugged.
    is it better?
    From what ive read if its the same your maf is fecked.
    But im no expert and try the search button and look for maf
    Jul 2012
    53
    just another thing have you cleaned the egr could possibly cause idle problem if sticking though id probably say issue with maf or throttle body if no leaks anywere tbh
    Apr 2012
    30
    what rpm should idle normaly sit at on the s3 is it 900rpm have read somewhere else tonight to check injector o ring/seals. also how does the hockey puck part of the breather system work does that also have a valve in it?
    Oct 2011
    760
    And one last thing to check is the wiring connector on the throttle body (bottom one) check its not lose or wiring bad.
    Oct 2011
    760
    840 mine is on vcds (s3 and stays steady)
    Apr 2012
    30
    cool il have a look at that in the morning can any of the electronics on the throttle be changed behind the black plastic cover.
    Oct 2011
    760
    ive been told to leave the the stuff behind the black plate alone.
    But im sure someone will be along shortly to correct me
    Apr 2012
    30
    opened it looked and shut itagain lol wont touch anything in there cleaned throttle body again revs still bouncing runs fine for first minute or so then starts its never straight away even when starting from hot took injectors out tonight checked o rings all good no leaks there. been radinga bit more on the net and think it might be a dogy 02 sensor maybe?
    Apr 2012
    30
    after reading a fair bit on the net found that the 02 sensor pre cat lamba sensor can get lazy and responds slow to change causing lagging info to the ecu mine ran fine for the first 10 seconds after a start from warm then started bouncing from 720 760 rpm after unpluging sat perfect at 800 rpm going to fit new sensor tonight
  1. Replies: 1
    Last Post: 23rd April 2012, 14:44
  2. Bounce at idle
    By Mattfaced in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st March 2010, 21:55
  3. Bouncing Idle?
    By spannah in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th January 2008, 11:56
  4. Rough Idle
    By melman in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th April 2007, 19:29
  5. 'bouncing' idle
    By rossparkman in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th December 2004, 17:36
