Does anybody know if the k03 oil and water feeds will fit the k04 on an audi a3 agu engine or will i have to buy all new ones??
Yeh you will need the K04 pipes, I think I have some spare if you need them.
Right got some braided pipe and heat shielding on the way have changed my maf back to standard with sleeve on will be looking out for vr6 clutch and abf flywheel then having cambelt and water pump done then off to r tech for the map. Prawn what did you do about the turbo bracket that sits on the bottom of the turbo and bolts to the engine my new turbo did not come with one and the one off my k03 will not fit??
just got some off ebay mate heres the link
HEAT SHIELD / HEAT BARRIER G2 DOUBLE MATERIAL 5.25mm | eBay
thought i would give it ago if its no good then a trip over to merlin motorsports it is lol.
