AH FabricationsChris Nott
Results 1 to 10 of 10
    Nov 2011
    pboro
    185
    Daft question about Coil Packs
    Hi all is there any upgrades you can get coil pack wise for an amk engine as i had one go on me tonite luckily i had a spare one, do any of the newer ones fit this model? many thanks
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,024
    TFSI coil packs...
    2.0 TFSI Coil Packs on a 1.8T
    Fitting TFSI coils
    <tuffty/>
    Oke Phill's Avatar
    Mar 2012
    147
    I followed both of tufftys guides he has posted, and ended up ordering the conversion spacers and tfsi coil packs from Awsome Gti £142 all in, worth every penny the my car runs much better.
    Here is a pic of them fitted.
    Nov 2011
    pboro
    185
    thanks tuffty and oke phill will enquire, do you use the same plugs as ive got a set of brand new platinum ones laying around somewhere which i bought ages ago.
    is that a recirculating valve in your pic or a atmoshperic? thanks
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,024
    Quote Originally Posted by S3_chris 11 View Post
    is that a diverter valve in your pic or a bov? thanks
    Same plugs yes... you can gap them to 0.85mm though from the std 0.8mm (or 0.7mm on a mapped engine)
    Its a diverter in the picture... std Audi management doesn't like BOVs...
    <tuffty/>
    Nov 2011
    pboro
    185
    Nov 2011
    pboro
    185
    cant find any spacers though just an ecs coil pack hold down kit
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,024
    You don't have to use the spacers tbh... I don't and have had no issues... this is only relevant on cam covers designed for push in packs... if converting from bolt downs (APY S3's not AGU's unless doing an ICM delete) then you will need them as they will flap about... mine are in solid as a rock..
    <tuffty/>
    Nov 2011
    pboro
    185
    i think mine is the push in design, how bad is it that i cant remeber even though ive had that engine to bits more times than i can count one one hand
    Oke Phill's Avatar
    Mar 2012
    147
    All the info on plugs are in the top two threads, and the info to work out what type of rocker cover you have vs if you need spacers. I did try the coils without the spacers at first and they fitted really nice, but got the spacers cos i think they look good.
    I found with awsome they did not advertise the spacers but call them and ask for them, and they have a fresh batch in.
    As for the valve, as Tuffty says it is a diverter. But that is a temp pipe that will be going,lol.
  1. coil pack questions?
    By sk8xtrm in forum A4/S4 forum(B5 Chassis)
    Last Post: 31st January 2011, 23:42
  2. quick coil pack question
    By domburg in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th February 2010, 14:13
  3. Coil pack question
    By Haglos in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd February 2010, 20:04
  4. Question about xenon power packs
    By johal87 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th August 2009, 00:09
  5. Hi All - Coil Pack Question
    By heli_madken in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 30th April 2008, 12:44
