AH FabricationsChris Nott
    tonks s3's Avatar
    May 2012
    33
    amk S3 fault codes please help :(
    Hello there I'm fairly new to the forum and to Audi so any help would be amazing, one of my mates plugged into my car the other weak due to it throughing up the engine management light,esp and abs my front left wheel bearing is going to be replaced which could be 1 or 2 faults cleared, but for the others I'm very confused!.
    Engine codes faults
    17544
    16395
    18010
    17947
    00283
    65535
    01316
    if anyone could help with some solutions and maybe pictures with these would be much appreciated cheers tonks
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    If you could either post up the VCDS output or have a look here (Category:Fault Codes - Ross-Tech Wiki) first to get the descriptions that would help mate...
    The codes by themselves don't mean alot...
    For example... 17544 is:
    17544/P1136/004406 - Ross-Tech Wiki
    17544/P1136/004406 - Fuel Trim: Bank 1 (Add): System too Lean
    Possible Solutions
    Check Mass Air Flow (MAF) Sensor
    Check Fuel Pressure Regulator
    Check Fuel Pump
    Check Intake/Exhaust System for Leaks
    Check Secondary Air Injection for Leaks
    Check Vacuum Lines for Leaks
    Special Notes
    Fuel Trim Info
    When this fault is stored and external vacuum leaks are not found, less obvious problems may be present:
    Check Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80)
    Check Brake Booster and Hoses
    Check Electric Vacuum Pump ( If Applicable )
    Check Crankcase Ventilation System for faulty components
    This indicates a big vacuum leak...
    Have a look at the rest on the wiki and post up the ones you are not sure about...
    <tuffty/>
    tonks s3's Avatar
    May 2012
    33
    Ohh thanks for that tuffty great help! I've done n249 bypass and I am running a 008p anywhere you would look for the leak?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    Most leaks are in the pipes under the inlet manifold...
    <tuffty/>
    tonks s3's Avatar
    May 2012
    33
    Cheers dude!
  1. fault codes - please help
    By niaz7 in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th April 2011, 16:58
  2. fault code!! please help
    By spencerdale in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th June 2010, 10:00
  3. Fault code. Please help!
    By mark_sarah in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th May 2010, 22:16
  4. Issues with a3 tdi sportback..........fault codes......please help!
    By vw754 in forum VCDS (formerly VAG-COM) forum
    Last Post: 19th January 2010, 22:59
