Chris NottEM Tuning
Thread: pipe on air box
    Jun 2012
    22
    pipe on air box
    ok guys so finally found the time to have a little look around my s3 after owning it for 3 weeks
    on the air box, above the filter there is a plastic pipe coming of to the side and heading to underneath the inlet. However it is open at the end. someone has half tape'd it up.
    Where should this be going??? as at the moment it will be sucking in air and missing the filter
    Oct 2011
    760
    look up sai delete in the stickies at the top of the page.
    Has all the routing of the pipes or you can just delete it.
    Delete it the whole thing it only works for 90 secs on start up
  1. 1.9tdi air box pipe.
    By chewy. in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th March 2010, 12:57
  2. The old air box mod-Where do I get 80mm pipe from??
    By keendean in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th January 2006, 10:04
  3. S3 pre 2000/ post 2000 air box.
    By pure in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th September 2004, 08:40
  4. Turbo Air Box Modifications
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th June 2004, 09:22
  5. air sensors in the air box?
    By Bradley in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th June 2004, 12:57
