AH FabricationsChris Nott
Results 1 to 17 of 17
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    Fluttery noise instead of DV noise.
    Hi ASN.
    Over the last week or so i have been occasionally getting a fluttery noise when i let off the throttle.
    Where i usually get a nice clean/ crisp tsh....
    I assumed i had a boost leak, so today i smoke tested my system.... It was fine, bar a little seap around the oil cap (is this bad?)
    It held a constant 10 Hg02?..(whatever that means)
    My next thought would be the DV (007p) but running a yellow spring i assume it wouldnt flutter?
    Its a very difficult noise to describe, Almost like a heatshield rattle but more plastic-cy.
    And help or advise on what to check next appreciated.
    (Tomorrow im going to stick the mityvac on the DV see if its holding vaccum)
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    Sounds like you have a boost leak. Perhaps a split hose. I've had this same nose a few times.check that all clamps etc are secure, also check you vacuum aswell
    Word!!!
    My A3/Martys Golf would smash that, and this guys £7000 GT9743 supercharged love machine.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,520
    your dump valve obv isnt operating properly. give it a service and check over all those pipes.
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    Are you certain the Dv isnt working?. it Doesnt sound metallic.
    As i said, i smoke tested it today.. No leaks! none, nothing, natta.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,520
    IF, and its a big if, the noise is what you say it is, a flutter, than that would be compressor stall, and would only happen a high boost with a dodgy dumpvalve
    (boost stuck in the boost system going back through the compressor wheel)
    but like i say, thats going off the 'flutter' description.
    it can also be described as a pigeon type noise lol, coooo
    obv i could be wrong. check the DV first to eliminate this.
    S3Zek's Avatar
    Sep 2011
    407
    Mine did this when one of the small pipes split off from the left underside of the inlet plenum, worth a look
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    Is there a guide on how to service a 007p?
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    Unscrew the top. Take out the piston and spring, remove 3 rubber seals, clean it up. New seals in with a bit of lube (provided), spring in, new piston thing in with a bit of the lube, screw top back on. You should get new springs too, I did anyway.
    Hope that helps.
    MODS - Custom Code phase 1, 007p DV, various powerflex bushes, EBC grooved and drilled - red stuff pads, N249 deletion. Badger5 V2 80mm TIP. Scorpion backbox + custom centre section, LCR front splitter, Jetex Fr-08001, R32 rear ARB, Forged IE rifle drilled rods, 20mm rear & 15mm front spacers.
    TO DO - Coilovers, adjustable tie arms, DP/mani/decat, FMIC and new remap
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    Ah, easy then..
    Ill check it today.
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,865
    Quote Originally Posted by MrCSW View Post
    http://www.forgemotorsport.co.uk/con...duct=FMCL007PA
    servicing instruction at the bottom,I purchased a service kit which has all the internals for iirc 20 quid
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,318
    My bet would be on a kinked hose to the top fo the DV, that would stop the DV from working but wouldn't show up on a smoke test or leak boost at all.
    I did some work for a chap who was insistant he wanted the engine cover back on after a catch can install on an A3, so I modified it to fit, but then couldn't work out why it was fluttering rather than dumping.
    Turned out to be the engine cover just pressing on the vacuum tube and kinking it.
    S321BAM's Avatar
    I lost the rod lottery
    May 2010
    Plymouth
    102
    I had this recently, the pipe coming off the top of the dv had bent over and caused the pipe to collapse were it was bent, straightend it out and job done.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Check the pipe for wear, that goes from the n75 valve to the actuator...
    Nov 2011
    pboro
    185
    did it sound like this? S3 Turbo Chatter - YouTube
    as mine started to make this noise the other day, sounds a funky different, can it damage you turbo as im pretty sure my mates 3.2 volvo turbo sounds like this but hes made his do it as says it wont ever damage anything as hes blocking a vaccum pipe and its just wastegate noise
    he thinks i should just keep it as it is but i dont want to risk damaging anything or worst case blowing the turbo
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    Ok,
    in between rain spells today.
    I checked the hose from n75 to actuator- Thats fine.
    Checked the Manni to Dv hose, looked fine and replaced it anyway.
    Popped the DV off and opened her up.
    It was a bit dirty inside, few oiley smudges.
    When i re assembled i thought i would check the operation of the DV see if it holds vaccum.
    Push the piston up from lower port, cover the vac nipple..
    Then the piston drops approx 1/2 way through its travel?. but does not close fully.
    Is this normal?
    cjsuk's Avatar
    Feb 2012
    Leeds
    561
    Ok,
    Is this normal?
    Its normal to drop a bit, my std one and forge one does it, as long as it stays up your ok (unless it stays when you let go lol)
    cjsuk's Avatar
    Feb 2012
    Leeds
    561
    Also and please don't quote me on this; if there is a problem with the N75/N249?? (think its N249) that can cause the sound, i'm sure I read it some where.
  1. Strange Noise when reversing
    By Nimo in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th December 2009, 18:40
  2. Strange noise - anybody got a clue !?
    By audi_girl in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st February 2003, 16:52
  3. Cold Startup Noise
    By mramage in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd January 2003, 21:52
  4. Whirring noise
    By A4Steve in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th January 2003, 12:32
  5. Phat noise unit?
    By Banwell in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th January 2003, 18:33
