Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By jezzy
Thread: B5 TIP fitting guide for non ESP cars?
    Sep 2010
    Devon
    756
    As above really, just wondering if anyone has a guide for fitting a B5 TIP to a non esp car? Looking forward to fitting the tip and Jetex filter on monday, is there any other bits and pieces I need to buy first?
    Thanks all
    Badger 5 tuned 340 bhp / 350 lbft sleeper
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,427
    Quote Originally Posted by slowcoach3 View Post
    Thanks all
    Just a bit of extra plumbing, as the DV and Crank breather thing are located slightly different, and you need to put a filter thing on the end of the SAI plumbing that goes into the airbox and secure it somewhere, since the airbox will no longer be there!
    Oct 2011
    759
    sai delete?
    Benjiman46 likes this.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,222
    Secondary air intake, its the plastic pipe that comes offthe airbox.
    Sep 2010
    Devon
    756
    Thanks guys, I'm going to be be doing a SAI delete at the same time, already unplugged it the other day after a failed attempt at fixing it! Is the n75 going to be a problem, I had it in my head it was on the other side as it were on later cars?
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,222
    N75 on ours is near the battery and not the bulkhead like later cars, i just used some silicone hose and a 90o plastic elbow for the n75 to connect to the tip.
    Oct 2011
    759
    sorry thats what i meant sai delete.
    if you do the delete, i found that when you undo the pump on the bottom bracket, hit the bracket with a hammer to bend it back towards passenger side, the whole pump just falls out after a couple of hits. saves so much time trying to get it out, then the bolts to the bracket are exposed, the top bolt on the bracket is more accessable if you remove the dipstick. make sure you have a new dipstick handy if yours is an old dipstick. got my pump off in half hour using this method
    Sep 2010
    Devon
    756
    Thanks jezzy, I know what I'm doing with the SAI, it's just the B5 TIP!
    Benjiman46's Avatar
    R-Tech Terrorist
    Feb 2012
    Worksop
    547
    If you can do the SAI delete, the B5 TIP should be no problem at all for you
    1.8 litre porsche eater!
    R-Tech Terrorist Squad - 265bhp & 275lbft
    Sep 2010
    Devon
    756
    Cheers mate, I'll find out tomorrow after my brake discs have been skimmed......New lcr brembo's have warped the discs inside 3 weeks and getting the horrendous juddering sorted is taking priority!
  1. s3 tip pipe on apy non esp modal
    By Delaney1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th May 2010, 18:28
  2. Any guides for fitting springs?
    By xs2man in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th June 2008, 23:47
  3. Need a fitting guide for PSS9s.
    By pablo in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th April 2008, 19:17
  4. Replies: 3
    Last Post: 20th September 2007, 23:50
  5. Samco hose for non-ESP S3?
    By dultanur in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th October 2006, 21:52
